Ubrigens Posted August 12, 2009 Author Posted August 12, 2009 What's the default program that open *.DWG file? See image posted below: Not at all sure how you produced image,but the equivalent image on my system shows Autocad Application rather than Autocad Dwg Launcher Quote
ReMark Posted August 12, 2009 Posted August 12, 2009 It's killing me therefore I just have to ask. Why did you set it up this way (under My Documents) in the first place? Quote
CADMASTER1128 Posted August 12, 2009 Posted August 12, 2009 Not at all sure how you produced image,but the equivalent image on my system shows Autocad Application rather than Autocad Dwg Launcher It is a simple Screen Print. To create one just press Ctrl + Alt + Prt Scr. Paste it into Paint and then save it as a JPEG. Quote
CADMASTER1128 Posted August 12, 2009 Posted August 12, 2009 Not at all sure how you produced image,but the equivalent image on my system shows Autocad Application rather than Autocad Dwg Launcher Why dont you try to change that? Quote
Ubrigens Posted August 13, 2009 Author Posted August 13, 2009 It's killing me therefore I just have to ask. Why did you set it up this way (under My Documents) in the first place? Sorry Mark---Years ago I had R14,which also used My Documents and I've just carried on that way.When I looked in "Help" at the start of this problem,I found a reference to "rememberfolders",which does point to My documents as the site for stored drawing files. Looking further at "options" there is a project Search file category,which currently has a stop sign and empty quoted. Is this connected in any way? Quote
Ubrigens Posted August 13, 2009 Author Posted August 13, 2009 Why dont you try to change that? Have tried to change but cannot find any ref to drawing launcher! Quote
Ubrigens Posted August 16, 2009 Author Posted August 16, 2009 It's killing me therefore I just have to ask. Why did you set it up this way (under My Documents) in the first place? I have made some progress at last.!!!!! I have found,purely by accident,that in tools/options/profiles,if I select "reset",my setup changes,but both "open" file and "save as" work as they did before------the down side is,that when I exit Autocad and then reopen and try"open" again---it crashes.Could you comment on this development,please?? Quote
