bcarp Posted May 19, 2008 Posted May 19, 2008 I am working with some drawings sent to me that have been converted down to Version 2k. Foe some reason these drawings wont allow me to copy to my clip board so I can paste into another drawing. Additionally sometimes after tryaing the copy with base point command when I save before going out and error message comes up that says "unpredictable error - access violation line 820. Anyone have any ideas how to fix this? Quote
dtkell Posted May 19, 2008 Posted May 19, 2008 Sounds like you have AEC objects from a newer version still in your drawing. Get whoever sent it to you to use AECexporttoAutoCAD to remove and save to your version. Or, save to dxf, R12. Then dxfin to a clean drawing. Quote
zars Posted May 19, 2008 Posted May 19, 2008 I'm not sure but I have heard about some errors when saving down to version 2000, so you might want to check that out too. Check if this helps you Quote
Keys N Bass Posted May 23, 2008 Posted May 23, 2008 try a WBLOCK of the objects you want to copy then INSERT the block into the relevant drawing.. this is not the solution, but a quick-fix if you need to progress on with other things.. Quote
ReMark Posted May 23, 2008 Posted May 23, 2008 Wow. A lot of threads lately re: copy & paste errors don't you think? Quote
Guest Alan Cullen Posted May 23, 2008 Posted May 23, 2008 Yup, and I bet a lot of them are about that bug with 2007 that AGM keeps talking about. Quote
ReMark Posted May 23, 2008 Posted May 23, 2008 Anyone know how long this "bug" has been around? I thought I read of a hotfix for one version of it too. Quote
Guest Alan Cullen Posted May 23, 2008 Posted May 23, 2008 All I know is the bug is in 2007, and the hotfix applies to that 2007. So, basically, the person using 2007 has to apply the hotfix to his 2007, not the person recieving a file from that person. And lets face it, so many people are still using 2007 and are unaware of the problem, because it does not affect them. Quote
CADken Posted May 23, 2008 Posted May 23, 2008 try a WBLOCK of the objects you want to copy then INSERT the block into the relevant drawing.. this is not the solution, but a quick-fix if you need to progress on with other things.. I have found this to work... sometimes copy and paste does me wrong, so that's how I get around it. Quote
ReMark Posted May 23, 2008 Posted May 23, 2008 bcarp: See this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7450124&linkID=9240858 Quote
SLW210 Posted May 23, 2008 Posted May 23, 2008 As I have stated before, use DWGTrueView from Autodesk or DWGGateway from Solidworks to open newer versions in the older versions and do not ask anyone to back save for you. The Hotfix needs to be installed on the 2007 version. Quote
radon222 Posted July 7, 2009 Posted July 7, 2009 I just got hit with the Copy/Paste problem and DWGGateway didn't help it... but TrueView did Quote
