TonyD Posted August 13, 2009 Posted August 13, 2009 Hello all, I need to know if I can some how save a .dwg file that was created on a 64 bit system so a 32 bit system can recognize it. I'm in school and would like to do do my homework at home. The problem is I have a 64 bit system at home and the school has 32 bit systems. Both the instructor and IT guy say it can't be done. What is your experience? If I could some how do this it would save me a 1 hour round trip to school a week. Quote
tzframpton Posted August 13, 2009 Posted August 13, 2009 Yes it will work. I work with 64bit and all my co-workers use 32bit. We share all the DWG files on our network seamlessly. Quote
TonyD Posted August 13, 2009 Author Posted August 13, 2009 Yes it will work. I work with 64bit and all my co-workers use 32bit. We share all the DWG files on our network seamlessly. Is there a trick to it? I find it hard to believe my instructors and IT guys can't get it to work. Quote
Cad64 Posted August 13, 2009 Posted August 13, 2009 I've got the same set up as Styk. I work on a 64 bit machine and the rest of the office is on 32 bit machines. There is no problem sharing files. Quote
tzframpton Posted August 13, 2009 Posted August 13, 2009 Is there a trick to it? I find it hard to believe my instructors and IT guys can't get it to work. 64bit might not be the problem. Might be a version issue. Quote
Cad64 Posted August 13, 2009 Posted August 13, 2009 Styk may be right. What version of Autocad is your school using, and are you saving down to a format that can be opened on that version? Quote
Coosbaylumber Posted August 14, 2009 Posted August 14, 2009 64bit might not be the problem. Might be a version issue. We had this same problem in the 16 versus 32 bit systems. Our solution was to erase the older file via name, then SAVE or SAVE-AS and exit immediately. Used same exact software, and got two different results, and often if we did not Erase the old one, then got an error message stating an older version existed, and cannot overwrite. By doing this it was easily was then picked up on any office system. We easily could go from 16 to 32 easily, but not backwards, like from 32 to 16, same software or not. Has something to do with how the hard drive is formatted back when, so cannot be altered. Wm. Quote
