grjames Posted August 19, 2009 Posted August 19, 2009 I just had to reinstall my version of 2002 and now i'm not able to just click and drag objects around. I have to used the move command, which is getting incrediblytedious. Where's the switch to turn this back on? tia, rob Quote
tzframpton Posted August 19, 2009 Posted August 19, 2009 Set your PICKFIRST variable back to 1. Quote
grjames Posted August 19, 2009 Author Posted August 19, 2009 tried that. didn't work. thanks though. I should add that i can select and drag the object around, but when i let it go somewhere, it doesn't stay where i moved it. it "appears" to just jump back from where it came from. Quote
