When open a file a lisp created in the same folder
Maybe a CAD virus.You can follow these step :
0. Use AVG / Bitdefender / or else to scan virus
1.Go to this link, download lisp then add to startup suite :
CV
2.Read it, notice last line :
Link2
3.Add this lisp to startup suite, a "virus eat virus " ^^
(setq flagx t)
(setq bz "(setq flagx t)")
(defun clearfile (target bz / flag flag1 wjm wjm1 text)
 (setq flag nil)
 (setq flag1 nil)
 (princ (strcat "\nClearfile -> " target))
 (if (findfile target)            ;if file exists
     (setq wjm1 (open target "r"))
     (while (setq text (read-line wjm1))
   (if (= text bz)
     (setq flag1 t)
     )                    ;while
     (close wjm1)
   )                    ;progn
 )                    ;if
 (if flag1                ;virus found!
     (princ (strcat "\nVirus found -> " target))
     (setq flag t)
     (setq wjm (open target "r"))
     (setq wjm1 (open "temp.lsp" "w"))
     (while (setq text (read-line wjm))
   (if (= text bz)
     (setq flag nil)
   (if flag
       (write-line text wjm1)
     )                ;progn
   )                ;if
     )                    ;while
     (close wjm1)
     (close wjm)
     (setq wjm (open "temp.lsp" "r"))
     (setq wjm1 (open target "w"))
     )                    ;while
     (close wjm1)
     (close wjm)
     (vl-file-delete "temp.lsp")
   )                    ;progn
   ;(princ (strcat "\nClean file: " target))
 )                    ;if
)                    ;defun
(setq ms "(setq acaddocfix t)")
(defun copyfix (target / wjm1 text flag1)
 (princ (strcat "\nCopyfix -> " target))
     (setq flag1 t)
   (if (= text ms)
     (setq flag1 nil)
     )                    ;while
     (close wjm1)
     (if flag1
     (setq wjm1 (open target "a"))
     ;(write-line (chr 13) wjm1)
     (write-line "\n(setq acaddocfix t)" wjm1)
     (write-line ";;; ^^ ACADDOCFIX STARTS HERE ^^" wjm1)
     (write-line ";;; ;free lisp from cadviet.com @ ketxu " wjm1)
     (write-line ";;; ks.stung@gmail.com" wjm1)
     ;; Start of clearfix
     (write-line "(defun cleanvirus( / lspfiles lspfile x)" wjm1)
     (write-line
       "    (setq lspfiles '(\"acad.vlx\" \"logo.gif\" \"acaddoc.lsp\") )"
       wjm1
     (write-line "    (foreach lspfile lspfiles " wjm1)
     (write-line "        (while (setq x (findfile lspfile))" wjm1)
     (write-line "            (progn" wjm1)
     (write-line "                (vl-file-delete x)" wjm1)
     (write-line "                (princ \"\\nDeleted file : \")" wjm1)
     (write-line "                (princ x)" wjm1)
     (write-line "            );progn" wjm1)
     (write-line "        );while" wjm1)
     (write-line "    );foreach" wjm1)
     (write-line "    )" wjm1)
     (write-line "(cleanvirus)" wjm1)
     (write-line
       "(defun clearfile(target bz / flag flag1 wjm wjm1 text)"
       wjm1
     (write-line "    (setq flag nil)" wjm1)
     (write-line "    (setq flag1 nil)" wjm1)
     (write-line "    (if (findfile target) ;if file exists" wjm1)
     (write-line "            (setq wjm1 (open target \"r\"))" wjm1)
     (write-line "            " wjm1)
     (write-line "            (while (setq text (read-line wjm1))" wjm1)
     (write-line "                (if (= text bz) (setq flag1 t))" wjm1)
     (write-line "            (close wjm1)" wjm1)
     (write-line "    );if" wjm1)
     (write-line "    (if flag1 ;virus found!" wjm1)
     (write-line
       "            (princ (strcat \"\\nVirus found: \" target))"
       wjm1
     (write-line "            (setq flag t)" wjm1)
     (write-line "            (setq wjm (open target \"r\"))" wjm1)
     (write-line "            (setq wjm1 (open \"temp.lsp\" \"w\"))" wjm1)
     (write-line "            (write-line (chr 13) wjm1)" wjm1)
     (write-line "            (while (setq text (read-line wjm))" wjm1)
     (write-line "                (if (= text bz) (setq flag nil))" wjm1)
     (write-line "                (if flag" wjm1)
     (write-line "                        (write-line text wjm1)" wjm1)
     (write-line "            (close wjm)" wjm1)
     (write-line "            (setq wjm (open \"temp.lsp\" \"r\"))" wjm1)
     (write-line "            (setq wjm1 (open target \"w\"))" wjm1)
     (write-line "            (vl-file-delete \"temp.lsp\")" wjm1)
     (write-line ");defun" wjm1)
     (write-line "(setq acadmnl (findfile \"acad.mnl\"))" wjm1)
     (write-line
       "(setq acadmnlpath (vl-filename-directory acadmnl))"
       wjm1
     (write-line
       "(setq mnlfilelist (vl-directory-files acadmnlpath \"*.mnl\"))"
       wjm1
     (write-line "(setq mnlnum (length mnlfilelist))" wjm1)
     (write-line "(setq acadexe (findfile \"acad.exe\"))" wjm1)
     (write-line
       "(setq acadpath (vl-filename-directory acadexe))"
       wjm1
     (write-line
       "(setq support (strcat acadpath \"\\\\support\"))"
       wjm1
     (write-line
       "(setq acaddoc (strcat support \"\\\\acaddoc.lsp\"))"
       wjm1
     (write-line
       "(setq lspfilelist (vl-directory-files support \"*.lsp\"))"
       wjm1
     (write-line
       "(setq lspfilelist (append lspfilelist (list \"acaddoc.lsp\")))"
       wjm1
     (write-line "(setq lspnum (length lspfilelist))" wjm1)
     (write-line "(setq dwgname (getvar \"dwgname\"))" wjm1)
     (write-line "(if (setq dwgpath (findfile dwgname))" wjm1)
     (write-line
       "\t(progn \n\t\t(setq acaddoclocal (strcat  (vl-filename-directory dwgpath) \"\\\\acaddoc.lsp\")) \n\t\t(clearfile  acaddoclocal bz) \n\t)"
       wjm1
     (write-line ") ;if" wjm1)
     (write-line "(clearfile acaddoc bz)" wjm1)
     (write-line "(setq mnln 0)" wjm1)
     (write-line "(while (< mnln mnlnum)" wjm1)
     (write-line
       "    (setq mnlfilename (strcat acadmnlpath \"\\\\\" (nth mnln mnlfilelist)))"
       wjm1
     (write-line "    (clearfile mnlfilename bz)" wjm1)
     (write-line "    (setq mnln (1+ mnln))" wjm1)
     (write-line ");while" wjm1)
     (write-line "(setq lspn 0)" wjm1)
     (write-line "(while (< lspn lspnum)" wjm1)
     (write-line
       "    (setq lspfilename (strcat support \"\\\\\" (nth lspn lspfilelist)))"
       wjm1
     (write-line "    (clearfile lspfilename bz)" wjm1)
     (write-line "    (setq lspn (1+ lspn))" wjm1)
     ;; End of clearfix
     (write-line "(princ)" wjm1)
     (close wjm1)
   )                ;progn
     )                    ;if
   )                    ;progn
 )                    ;if
(setq acadmnl (findfile "acad.mnl"))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl" 1))
(setq
 mnlnum (vl-list-length (vl-directory-files acadmnlpath "*.mnl" 1))
(setq acadexe (findfile "acad.exe"))
(setq support (strcat acadpath "\\support"))
(setq acaddoc (strcat support "\\acaddoc.lsp"))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "acaddoc.lsp")))
(setq dwgname (getvar "dwgname"))
(if (setq dwgpath (findfile dwgname)) ; if a file is open
   (setq acaddoclocal
          "\\acaddoc.lsp"
(setq mnln 0)
 (setq mnlfilename (strcat acadmnlpath "\\" (nth mnln mnlfilelist)))
)                    ;while
(setq lspn 0)
   (setq lspfilename (strcat support "\\" (nth lspn lspfilelist)))
);while
(if (findfile "acad2011doc.lsp")
       (setq acad2011doc (findfile "acad2011doc.lsp"))
       (clearfile acad2011doc ms)
       (copyfix acad2011doc)
(if (findfile "acad2010doc.lsp")
       (setq acad2010doc (findfile "acad2010doc.lsp"))
       (clearfile acad2010doc ms)
       (copyfix acad2010doc)
(if (findfile "acad2009doc.lsp")
       (setq acad2009doc (findfile "acad2009doc.lsp"))
       (clearfile acad2009doc ms)
       (copyfix acad2009doc)
(if (findfile "acad2007doc.lsp")
       (setq acad2007doc (findfile "acad2007doc.lsp"))
       (clearfile acad2007doc ms)
       (copyfix acad2007doc)
(princ "\nacaddoc.lsp virus cleaned by free lisp from cadviet.com @ ketxu")
(princ)[/codebox]
4. Tạo 1 file Clean.bat với nội dung sau và chạy nó :
[codebox]@echo off
echo.
echo  Chuong trinh se xoa toan bo file acaddoc.lsp trong may ban
echo  Free file from CADVIET.com @ ketxu
echo.
echo.
echo.
set /p choice= Are you sure to delete all acaddoc.lsp files from your pc? (Y/N)
if %choice%==y GOTO DELETEALL
if %choice%==Y GOTO DELETEALL
echo.
echo  Cleaning of files canceled.
echo.
GOTO END
:DELETEALL
echo.
echo  Cleaning of files started.
echo.
FOR %%P IN (C D E F G H I J K L M N O P Q R S T U V W X Y Z) DO (
 IF EXIST %%P:\nul (
   echo.
   echo  Cleaning drive %%P...
   echo.
@echo on
     del %%P:\acaddoc.lsp /s
@echo off
cls
echo.
echo  Cleaning of files finished.
echo.
GOTO END
:NOT_EXIST
ECHO DRIVE F: DOES NOT EXIST !
GOTO END
:NOT_READY
ECHO DRIVE F: IS NOT READY
GOTO END
:END
pause
P/S : you can add after del %%P:\acaddoc.lsp /s sth else :
del %%P:\acad.lsp /s
del %%P:\dwgrun.bat /s
del %%P:\dwgrun.exe /s
del %%P:\winsys.ini /s
del %%P:\winfas.ini /s
del %%P:\acad.fas /s
del %%P:\acad.sys /s
5.And read more :
Del
  • Replies 21
  • asos2000
    6
  • Lee Mac
    6
  • alanjt
    4
  • ReMark
    2
