Cad O Cad Posted August 21, 2009 Posted August 21, 2009 Hi all!, im new to cad tutor and also kind of new to VB. well here is the deal.... I am have a drawing that has a certain piece of text on it i.e. LFT000000025899.. and i need a selection set that basically says look at that number and match it to the file name of the drawing. If the number on the drawing matches the file name then the program continues but if not..then it writes the error to a word doc and user gets tht report after the program runs...CAN ANYONE GIVE ME SOME INSIGHT...IVE SEARCHED EVERY WHERE!!:cry: Quote
SEANT Posted August 21, 2009 Posted August 21, 2009 I am too pressed for time this morning to offer much help; perhaps this weekend. One suggestion I would make, though, is to present as many details (VBA-VB6-VB.NET, etc.) and examples (general file that shows if text is DTEXT-MText-Attribute Reference, etc) you can. This will help us offer pertinent information. Also, that increased level of input from your side is more effective at generating the interest of a potential responder. Quote
Cad O Cad Posted August 21, 2009 Author Posted August 21, 2009 ok cool i appreciate it..well here is what i have so far Function TextCheckerNEWNEW(strErrors)'************************************************************** '* '* Variable Declarations '* '************************************************************** Dim S2 As AcadSelectionSet Dim bInterimName As Boolean Dim Ftyp1(6) As Integer 'Dim Ftyp(9) As Integer Dim k As Long Dim Fval1(6) As Variant 'Dim Fval(9) As Variant '************************************************************** '* '* Program Begins '* Makes sure there is a INTERIM NUMBER on the part '************************************************************** 'strErrors = strErrors & "-----------------------Beginning Annotation check----------------------;" Ftyp1(0) = -4: Fval1(0) = "Ftyp1(1) = -4: Fval1(1) = "Ftyp1(2) = 0: Fval1(2) = "MTEXT" Ftyp1(3) = 0: Fval1(3) = "TEXT" 'Ftyp1(4) = 1: Fval1(4) = "LFT" Ftyp1(4) = -4: Fval1(4) = "OR>" Ftyp1(5) = 67: Fval1(5) = 1 Ftyp1(6) = -4: Fval1(6) = "AND>" Set S2 = ThisDrawing.SelectionSets.Add("S2") S2.Select acSelectionSetAll, , , Ftyp1, Fval1 For k = 0 To S2.Count - 1 If Left(S2(k).TextString, 1) = "LFT" strErrors = strErrors & "Interim Number Found On Document.;" bInterimName = True 'And InStr(1, S2(k).TextString, "#") 'Else 'If Left(S2(k).TextString, 1) = "LFT" And InStr(1, S2(k).TextString, "#") 'bInterimName = True 'End If End If Next k ThisDrawing.SelectionSets("S2").Delete If bInterimName True Then Call ErrorDisplay("Interim Number Does Not Match File Number. Lofter Please Correct and Re-Run QA.", Null, strErrors, False) End If Quote
Cad O Cad Posted August 21, 2009 Author Posted August 21, 2009 Anyone out there tryin to help me out Quote
SEANT Posted August 21, 2009 Posted August 21, 2009 The code sample posted above shows a function designed to run in the middle of a larger block of code – which is a good thing. Any one particular Sub/Function should take on a very specific chore, but structure to be easily chained together with other focused code block to accomplish the desired task. That being said, however, one internal function leaves out a lot of background information. I’ve modified the function a bit (a few assumptions were made regarding parameters): Is this inline with the desired result of the overall task? Sub tester() 'tester routine to call the TextCheckerNEWNEW function If TextCheckerNEWNEW("test") Then MsgBox "Text Found." Else MsgBox "Text not Found.", vbCritical End If End Sub Function TextCheckerNEWNEW(strErrors As String) As Boolean '************************************************* ************* '* '* Variable Declarations '* '************************************************* ************* Dim S2 As AcadSelectionSet Dim bInterimName As Boolean Dim Ftyp1(6) As Integer Dim Fval1(6) As Variant Dim k As Long Dim entText As AcadText Dim entMtext As AcadMText '************************************************* ************* '* Program Begins '* Makes sure there is a INTERIM NUMBER on the part '************************************************* ************* 'strErrors = strErrors & "-----------------------Beginning Annotation check----------------------;" Ftyp1(0) = -4: Fval1(0) = "<AND" Ftyp1(1) = -4: Fval1(1) = "<OR" Ftyp1(2) = 0: Fval1(2) = "MTEXT" Ftyp1(3) = 0: Fval1(3) = "TEXT" Ftyp1(4) = -4: Fval1(4) = "OR>" Ftyp1(5) = 67: Fval1(5) = 1 Ftyp1(6) = -4: Fval1(6) = "AND>" On Error Resume Next ThisDrawing.SelectionSets.Item("S2").Delete 'to help during debugging On Error GoTo 0 Set S2 = ThisDrawing.SelectionSets.Add("S2") S2.Select acSelectionSetAll, , , Ftyp1, Fval1 For k = 0 To S2.count - 1 Select Case S2(k).ObjectName Case Is = "AcDbText" Set entText = S2(k) If entText.TextString = strErrors Then TextCheckerNEWNEW = True ThisDrawing.SelectionSets("S2").Delete Exit Function End If Case Is = "AcDbMText" Set entMtext = S2(k) If entMtext.TextString = strErrors Then TextCheckerNEWNEW = True ThisDrawing.SelectionSets("S2").Delete Exit Function End If End Select Next k End Function Quote
Cad O Cad Posted August 21, 2009 Author Posted August 21, 2009 Well yes...but i already have the Function called out in a previuos Sub.. But also i want it to do sumthing along these lines..if those two do not match (the LFT00004587 and the file name i.e. LFT00004587.dwg) then it records the error to a word doc and say sumthin like "LFT Number and File Name do not Match! Please Correct and Re-Run" Quote
SEANT Posted August 21, 2009 Posted August 21, 2009 The code I posted was not meant to be a solution to the task; it was more so I could understand what the function was meant to do. Bear in mind that I don’t know how the “previous Sub” acquired the info passed in (strErrors) or what the sub expects back (your function example does not have a return type). Presumably there is some other Sub set up to open all the drawings in a directory. Does the drawing name (strErrors?) still have the .DWG extension? Quote
Cad O Cad Posted August 21, 2009 Author Posted August 21, 2009 yes it does still have the dwg.ext..basically this is wat happens...the user clicks a button and a series of checks run to basically checka drawing....this is a check to make sure the drawing number matches the file name... and then the program keeps on running...if there are errors on the drawing that these checks caught then the report out to word document file and tell the user what to do. Quote
SEANT Posted August 21, 2009 Posted August 21, 2009 This attachment still uses a simple testing routine. Any preliminary Checking/Calling sub could call this modified TextCheckerNEWNEW function and respond in a manner similar to my tester sub. Make sure Microsoft Word is checked in Tools - References. Sub tester() 'Tester routine to Test TextCheckerNEWNEW and CreateDwgList 'Actual routine would probably search through numerous drawings in a directory Dim arrNameString() As String Dim i As Long Dim strTest As String strTest = "test.dwg" i = 0 If TextCheckerNEWNEW(strTest) Then 'do something if everything is okay Else ReDim Preserve arrNameString(i) arrNameString(i) = strTest i = i + 1 End If If i > 0 Then CreateDwgList (arrNameString) End Sub Function TextCheckerNEWNEW(ByVal strErrors As String) As Boolean '************************************************* ************* '* '* Variable Declarations '* '************************************************* ************* Dim S2 As AcadSelectionSet Dim bInterimName As Boolean Dim Ftyp1(6) As Integer Dim Fval1(6) As Variant Dim k As Long Dim entText As AcadText Dim entMtext As AcadMText Dim strText As String '************************************************* ************* '* Program Begins '* Makes sure there is a INTERIM NUMBER on the part '************************************************* ************* 'strErrors = strErrors & "-----------------------Beginning Annotation check----------------------;" Ftyp1(0) = -4: Fval1(0) = "<AND" Ftyp1(1) = -4: Fval1(1) = "<OR" Ftyp1(2) = 0: Fval1(2) = "MTEXT" Ftyp1(3) = 0: Fval1(3) = "TEXT" Ftyp1(4) = -4: Fval1(4) = "OR>" Ftyp1(5) = 67: Fval1(5) = 1 Ftyp1(6) = -4: Fval1(6) = "AND>" On Error Resume Next ThisDrawing.SelectionSets.Item("S2").Delete 'to help during debugging On Error GoTo 0 Set S2 = ThisDrawing.SelectionSets.Add("S2") S2.Select acSelectionSetAll, , , Ftyp1, Fval1 strErrors = UCase(strErrors) For k = 0 To S2.count - 1 Select Case S2(k).ObjectName Case Is = "AcDbText" Set entText = S2(k) strText = UCase(entText.TextString) Case Is = "AcDbMText" Set entMtext = S2(k) strText = UCase(entMtext.TextString) End Select If InStr(strText, ".DWG") = 0 Then strText = strText & ".DWG" If strText = strErrors Then TextCheckerNEWNEW = True ThisDrawing.SelectionSets("S2").Delete Exit Function End If Next k End Function Sub CreateDwgList(arrTitle As Variant) ' add a reference to the Word-library Dim intTitleCount As Integer Dim wrdApp As Word.Application Dim wrdDoc As Word.Document Dim wrdTable As Word.Table Dim wrdRange As Word.Range Dim xText Dim i As Long intTitleCount = UBound(arrTitle) + 1 Set wrdApp = GetObject(, "Word.Application") Set wrdDoc = wrdApp.ActiveDocument Set wrdRange = wrdDoc.Range wrdApp.Visible = True wrdRange.InsertAfter Text:="Drawings Improperly Designated" & vbCr wrdDoc.Paragraphs(1).NoLineNumber = True With wrdDoc.PageSetup.LineNumbering .Active = True .StartingNumber = 1 .CountBy = 1 .RestartMode = wdRestartContinuous End With For i = 1 To intTitleCount wrdRange.InsertAfter Text:=arrTitle(i - 1) & vbCr Next Set wrdDoc = Nothing Set wrdApp = Nothing End Sub Quote
Cad O Cad Posted August 24, 2009 Author Posted August 24, 2009 Ok...i will try this and see wat happens...i dont know why this is so confusing for me Quote
Cad O Cad Posted August 24, 2009 Author Posted August 24, 2009 Ok here is a sample of my code that i have for another checker in this routine...i basically want it in the same format.... Function CheckColorOfLayout(strErrors)Dim S3 As AcadSelectionSet Dim Ftyp(5) As Integer Dim errCount As Long 'Dim strErrors As String Dim Fval(5) As Variant Dim dEnd As Variant '************************************************************** '* '* Program Begins '* Looks for anything in paperspace not colored white '************************************************************** 'strErrors = strErrors & "-----------------------Beginning Entity Checker------------------------;" Ftyp(0) = -4: Fval(0) = " Ftyp(1) = 67: Fval(1) = 1 Ftyp(2) = -4: Fval(2) = " Ftyp(3) = 62: Fval(3) = 7 Ftyp(4) = -4: Fval(4) = "NOT>" Ftyp(5) = -4: Fval(5) = "AND>" 'ThisDrawing.SelectionSets("S3").Delete Set S3 = ThisDrawing.SelectionSets.Add("S3") S3.Select acSelectionSetAll, , , Ftyp, Fval If S3.Count > 0 Then For errCount = 0 To S3.Count - 1 S3(errCount).color = acWhite Next errCount strErrors = strErrors & "Layout entities color changed to White, no action required by Lofter.;" End If ThisDrawing.SelectionSets("S3").Delete End Function Quote
