AutoCAD error
i click anywhere on the tools palette and i get this error message and i cant do anything... any suggestions on how to fix it?
a repair of the installation didn't work. should i reinstall or is there an easier option?
this happens on all the palettes even the standard ones that come with autocad
Are you using plain AutoCAD or a vertical like Architectural or MEP, etc.?
I have something similar happen a few years ago and it turns out the update from Autodesk changed the paths to lots of stuff.
If you start with a shortcut on the desktop, copy that shortcut then right click, properities, finally remove the call to the profile you have been using. Save and close out of that, now dbl click on that shortcut and see if the palettes work.
hmmm i had just installed an update... i'll try what you suggested and answer you back
