Surface is out of date
I want to create a profile, but my surface can't work, it says,
"surface is out of date", is there a quick way to fix it, other than to re-triangulate?
By the way I am able to change contours to different intervals, like 2', 5' or 10' interval, which means the surface exist and is active! What is the issue here then?
Thank you
Nyaromulo
Surface.zip
Please, check the attachment in the first post
is it a data shortcut or in the actual drawing?
I just had to recreate surface, now I am good to go. thanks for the input
