LBUG42 Posted August 27, 2009 Posted August 27, 2009 Here Is My Problem The Engineer Here Wants To Know If I Can Open Or Import .stp & .iges Files? I Tried And Got No Where, Does Anyone Know Of A Way To Get To The Files So We Can Work On The Files Together? Or Is This Not Going To Work. Quote
ReMark Posted August 27, 2009 Posted August 27, 2009 I do not see STP or IGES files listed in my version (2009) of AutoCAD. What I do see is WMF, SAT, 3DS and DGN listed. Perhaps you need to use some other program as a go-between. Inventor? Quote
LBUG42 Posted August 27, 2009 Author Posted August 27, 2009 not sure he just wanted me to try an open them up and cannot just wanted to see if anyone knew of these files. i tried import and just opening them up nothing worked. Quote
Coosbaylumber Posted August 28, 2009 Posted August 28, 2009 I once had a friend who worked for Grumann aviation of Long Island. He would send me a file via E:mail, I was to expand it, then convert it into some version of Acad, and send on to another. Had to use the IGES-in comamnd quite often, as the Grumann software did not have any DXF-out at the time. The IGES file used to look like a single vertical line when it came in. This was misleading, for it came in as an X, Y, Z, fine and as all work had no Z component, it looked that way. Via Autocad, I rotated the file 90 degrees and there was everything then. Wm. Quote
ReMark Posted August 28, 2009 Posted August 28, 2009 The following was taken from the Technology Bulletin, e-vol 59, September, 2007 as written by Mark Lautenbach, Solutions Engineer-MCAD, Hagerman & Company regarding AutoDesk Inventor Suite 2008: "Inventor users everywhere have always had one thing in common. It has been difficult to use 3D models that come from a source other than Inventor. Sure, Inventor has been able to import IGES files. Inventor has even been able to use STEP files. STEP files have been the recommendation for quite a while as they typically have more consistent solids translation." Do you know anyone who uses Inventor? Are you a student? Students can download Inventor for free I believe. Quote
LBUG42 Posted August 31, 2009 Author Posted August 31, 2009 Thank You I Downloaded Inventor And Will Give It A Try. Quote
Tankman Posted September 2, 2009 Posted September 2, 2009 Thank You I Downloaded Inventor And Will Give It A Try. Let us know how it works out for you. I grew up next to Grumman on Long Island. A fun place to grow up. As a teen, I worked part time summers for Grumman. A great place to work. Quote
