Hy all,
Ive created a dynamic block with att , my dynamic block works fine but now when i insert it into a drawing it does'nt work the way it should, it says contraint problem? strange... is it an option, a value? can someone please help?
i added a dwg, now i can move the rectangle block, when the problem appears the line is not connected to dot. and stays horizontal.
txs Hook@rt
SP10.dwg
