I created a material (red vertical siding) on two of the four walls it shows up right on the other two walls its rotated at a 45 degrees. All the walls are one solid. any ideas why?
Also tried a horizontal siding with same results two of the four walls show correctly two of the four are rotated
Sounds like you need to adjust your material mapping. Type MATERIALMAP at the command line and try some of the options. Also, check your Autocad help files for information on UV Settings and Materials.
