Resizing block reference text.
I've got these surveyor points and the text is hilariously oversized. Is there any way to reduce the text size without exploding everything?
edit: Exploding it doesn't work anyway
So you're looking to globally reduce the size of all text or just that of the survey points?
what kind of points are they?
if you list them, what does it say?
I'd be willing to bet they are AEC points created in Land Development or possibly Civil 3D.
Either way the only way to resize w/o exploding them is with the software used to create them.
my exact thoughts.
if ldd, then the coding is nicely stored in dxf; civil 3d and you are pretty much SOL (if looking at proxy objects).
Thanks for all the advice everyone. Ideally, i'd just like to reduce the size of the surveyor text, but a reduction of all text would also work. Each point has 3 lines of text but they're lost when i explode the block. The text goes from the data to just the type.
For example, it'll go from
423
118.2
E/ OF RIPRAP
to
POINT
ELEV
DESC
Here's a LIST from one of the points. I'm not sure what they were created with.
Customization file loaded successfully. Customization Group: LAND
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CIVILDESIGN
Customization file loaded successfully. Customization Group: SURVEY
Customization file loaded successfully. Customization Group: EXPRESS
Loading AEC Base...
Loading AecCivilBase...
Loading AEC Base UI...
Loading AEC Project Base...
Loading AEC Base GUI...
Loading AEC Schedule Data...
Loading AEC Utilities...
Loading AEC Layer Manager...
Loading AEC Architectural Base...
Loading AEC Project UI...
Loading AEC Schedule...
Loading AEC Object Explode...
Loading AEC Recipe Base...
Loading AEC Detail UI...
Loading AEC Detail Base...
Opening a Release 14 format file.
Substituting [simplex.shx] for [LEROY.shx].
Substituting [simplex.shx] for [Eng_Modified.shx].
Substituting [simplex.shx] for [Low Res Filled.shx].
Substituting [simplex.shx] for [GEOMETRIC_FUTURA_HEAVY.shx].
Substituting [simplex.shx] for [font000.shx].
Substituting [simplex.shx] for [font127.shx].
Substituting [simplex.shx] for [uSTN_FANCY.shx].
Substituting [simplex.shx] for [iNTL_ENGINEERING.shx].
Regenerating model.
Press ENTER to continue:
Initializing....
......Done.
Loading AecCMapCogoCmds...
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
Loading AecDraft...
Loading AecLS...
Loading AecCivilApp...
Converting contour objects...
Initializing...
Command: COMMANDLINE
Command: properties
Command:
Automatic save to C:\AA2022-asbuilt_1_1_0561.sv$ ...
Command:
Command: *Cancel*
Command: *Cancel*
Command: _quit
Command:
Automatic save to C:AA2022-asbuilt_1_1_0561.sv$ ...
Command: layer
Command:
Command: list
1 found
                 BLOCK REFERENCE  Layer: "PNTS"
                           Space: Model space
                  Handle = 10ddd
      Block Name: "POINT"
               at point, X=1398933.14  Y=521990.60  Z=     0.00
  X scale factor:     48.00
  Y scale factor:     48.00
  rotation angle: 0d0'0"
  Z scale factor:     48.00
 Scale uniformly: No
 Allow exploding: Yes
                 ATTRIBUTE  Layer: "ELEV"
                           Space: Model space
                  Handle = 10dde
            Style = "S6"
            Font file = SIMPLEX.shx
            start point, X=1398938.85  Y=521988.66  Z=     0.00
           height      4.00
            value 119.38
              tag ELEV
this can easily be fixed in code, but i noticed that the points have an X and Y value of 48. why not just scale them down. you can select them and change the X,Y through the properties menu. if this doesn't work, give a shout. we can work something.
423
118.2
E/ OF RIPRAP
to
POINT
ELEV
DESC
Loading AEC Base...
Regenerating model.
Initializing....
......Done.
Loading AecDraft...
Loading AecLS...
Initializing...
Command: properties
Command:
Command:
Command: *Cancel*
Command: *Cancel*
Command: _quit
Command:
Command: layer
Command:
Command: list
1 found
                           Space: Model space
                  Handle = 10ddd
      Block Name: "POINT"
 Scale uniformly: No
                           Space: Model space
                  Handle = 10dde
            Style = "S6"
           height      4.00
            value 119.38
              tag ELEV
Damn. I didnt notice the alterable scale the first time around. Thanks for pointing it out.
No problem.:)
Did that fix your problem?
