mr_mojo_risin Posted June 12, 2008 Posted June 12, 2008 Is there any way you can draw an irregular shped viewport in LT2008 (i.e. not a rectanlge)???? Cheers:oops: Quote
Hedgehog Posted June 12, 2008 Posted June 12, 2008 I'm not sure of the limitations of LT but if when you enter the MVIEW command you don't have options for Object or Polygonal then I think you're out of luck. Quote
mr_mojo_risin Posted June 12, 2008 Author Posted June 12, 2008 That's what I suspected. Cheers anyway:):) Quote
tzframpton Posted June 12, 2008 Posted June 12, 2008 I'm not sure of the limitations of LT but if when you enter the MVIEW command you don't have options for Object or Polygonal then I think you're out of luck. AutoCAD LT 2008 actually has these options. Just type MVIEW to invoke the command. Quote
mr_mojo_risin Posted June 12, 2008 Author Posted June 12, 2008 AutoCAD LT 2008 actually has these options. Just type MVIEW to invoke the command. When I type MVIEW, the options I get are: ON/OFF/Fit/Shadeplot/Lock/Restore/LAyer/2/3/4 Quote
tzframpton Posted June 12, 2008 Posted June 12, 2008 And this is AutoCAD LT 2008? Because we have 6 seats of LT 2008 and I just went to our other station and checked before I posted. Quote
mr_mojo_risin Posted June 12, 2008 Author Posted June 12, 2008 And this is AutoCAD LT 2008? Because we have 6 seats of LT 2008 and I just went to our other station and checked before I posted. It certainly is.:( Quote
James Posted June 12, 2008 Posted June 12, 2008 i thought this was a new addition to 2009, but i cannot be sure. it was (link http://lynn.blogs.com/lynn_allens_blog/2008/04/more-autocad-20.html ) Quote
Dipali Posted June 12, 2008 Posted June 12, 2008 When I type MVIEW, the options I get are: ON/OFF/Fit/Shadeplot/Lock/Restore/LAyer/2/3/4 yes, it is same in my LT2008 as well. Quote
GE13579 Posted June 12, 2008 Posted June 12, 2008 You can however use wipeouts to "shape" the viewport though... not a solution but a possible workaround... if wipeouts are available in LT? Quote
