Hello!
Can I, and if so, how to change the default drawing save location?
When I make a new drawing and wish to save it for the first time it automatically opens the My Documents folder, but I would like to open some different folder.
When I edit existing drawing and wish to save it with another name, then it opens the folder in which the existing drawing is located - that is ok with me.
So, the point is just for the location of new drawing.
Edit: I am using Autodesk Map 3D with Raster Design 2007
Thanks
You can configure AutoCAD to always use a specified path by changing the default drawing folder using the REMEMBERFOLDERS system variable.
