alanjt Posted September 10, 2009 Posted September 10, 2009 Thought it was about time I posted code. At least, more than just randomly posting in threads. Just finished this and seemed like a good starting point. I know it's mostly information about core commands, but I'm sure it's still valuable to some. Information on how to manipulate/create/etc. LayerStates in code. Not sure when these were introduced, but they are working in 2009. I've also included a rewrite of the layerstate-save command to include the option to 'overwrite' LayerState, if already exists. Enjoy. ;;; --------------------------------------------------[LayerStateInfo.lsp Begin]------------------------------------------------------------ ;;; LayerState Manipulation Information and Subroutines ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; Aside from 'AT:LayerStateSave', Alan J. Thompson claims NO ownership and NO responsibility for following coding. All are core AutoCAD. ;;; Compiled from: "AutoCAD 2009 Help: Developer Documentation" ;;; Tested and verified using AutoCAD Civil 3D 2009 ;;; Compiled by: Alan J. Thompson, 09.09.09 ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; LayerState Values ;;; Combine numeric values to use more than one ;;; Example: (apply '+ '(1 2 4 8 16 32 64 128)) => 255 ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; Mask: An integer sum designating which properties in the layer state are to be restored. ;;; 1- Restore the saved On or Off value ;;; 2- Restore the saved Frozen or Thawed value ;;; 4- Restore the saved Lock value ;;; 8- Restore the saved Plot or No Plot value ;;; 16- Restore the saved VPVSDFLT value ;;; 32- Restore the saved Color ;;; 64- Restore the saved LineType ;;; 128- Restore the saved LineWeight ;;; 255- Restore everything ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; Restore Flags ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; Optional integer sum affecting how the layer state is restored. ;;; 1- Turn off all layers not in the restored layer state ;;; 2- Freeze all layers not in the restored layer state ;;; 4- Restore the layer state properties as viewport overrides (requires viewport to be not a nil value). ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; Commands (Return T if successful, nil if not): ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; Most useful, with information ;;; ---------------------------------------------------------------------------------- ;;; LayerStateDelete (layerstate-delete "LayerStateName") ;;; LayerStateList (layerstate-getnames "T to include hidden layerstates, Optional" "T to include xref layerstates, Optional") ;;; LayerStateRename (layerstate-rename "OldName" "NewName") ;;; LayerStateImport (layerstate-import "Filename.las & path") ;;; Example: (layerstate-import c:\\mylayerstate.las) ;;; LayerStateExport (layerstate-export "LayerStateName" "Filename.las & path") ;;; Example: (layerstate-export "Storm" "c:\\Storm.las") ;;; LayerStateRestore (layerstate-restore "LayerStateName" "Viewport ename, nil for ModelSpace" "RestoreFlags <- See above list") ;;; LayerStateImportFromDWG (layerstate-importfromdb "LayerStateName" "Filename.dwg & path") ;;; Example: (layerstate-importfromdb "Storm" "c:\\Storm.dwg") ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; All LayerState-* Commands (Refer to AutoCAD 20XX Help: Developer Documentation for additional info.) ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; layerstate-addlayers Adds or updates a series of layers to a layer state ;;; layerstate-compare Compares a layerstate to the layers in the current drawing ;;; layerstate-delete Deletes a layer state ;;; layerstate-export Exports a layer state to a specified file ;;; layerstate-getlastrestored Returns the name of the last restored layer state in the current drawing ;;; layerstate-getlayers Returns the layers saved in a layer state ;;; layerstate-getnames Returns a list of the layer state names ;;; layerstate-has Checks if a layer state is present ;;; layerstate-import Imports a layer state from a specified file ;;; layerstate-importfromdb Imports a layer state from a specified drawing file ;;; layerstate-removelayers Removes a list of layers from a layer state ;;; layerstate-rename Renames a layer state ;;; layerstate-restore Restores a layer state into the current drawing ;;; layerstate-save Saves a layer state in the current drawing ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; Rewrite of layerstate-save to include option to overwrite existing ;;; ---------------------------------------------------------------------------------------------------------------------------------------- ;;; AT:LayerStateSave (Option to overwrite) ;;; #Name - LayerState name ;;; #Mask - Numeric value for restoring options (see above list) ;;; #ViewportID - Ename (ads_name) of the viewport to which layerstatename should be restored. ;;; If viewport is nil, the layer state is restored to model space. ;;; Alan J. Thompson, 09.09.09 (defun AT:LayerStateSave (#Name #Mask #ViewportID #Overwrite) (and #Overwrite (layerstate-has #Name) (layerstate-delete #Name) ) ;_ and (layerstate-save #Name #Mask #ViewportID) ) ;_ defun ;;; ----------------------------------------------------[LayerStateInfo.lsp End]------------------------------------------------------------ Quote
