Gno Posted September 10, 2009 Posted September 10, 2009 Sup guys!! Is there anyway possible to design a functional conveyor belt(treadmill) on Inventor? Ive searched and search but found nothing. Does AI have such capabilities? I made one by sketching the loop (belt) then extruded the sketch. but it was only useful for visualizing belt on the two roller shafts that i have. The only thing i can think of would be to break the belt down into individual flats, then then constraining each flat edge to edge, then to the rollers using rotational translation,Tangent. I really would appreciate some advice on this. Quote
shift1313 Posted September 11, 2009 Posted September 11, 2009 Are you hoping to do some animations or dynamic simulations with this? do you need the wheels to drive the belt? can you give a little more info on what you would like to do with the model. Quote
Gno Posted September 11, 2009 Author Posted September 11, 2009 I plan on having one of the rollers/shaft/wheel coupled to a gearbox to drive the belt, while the second roller freespins on a bearing. Definitly want to be able to animate and simulate I appreciate the help Quote
