Kari H Posted September 11, 2009 Posted September 11, 2009 Hi All - I am having an issue. I have a file that has some type of viewport in the paper space. There is no border on it though to grip. I have all my layers on and unfrozen. No layers are locked. I can double click in the area of the "viewport" and it takes me to model space just like any normal viewport does, but when I go back to paper space, there is no viewport outer border again. Is there a setting that makes viewports invisible or something? Thank you! Quote
ScribbleJ Posted September 11, 2009 Posted September 11, 2009 Thats a good one! I can't wait to see what others have to say about this. In the 18 years I have been working with AutoCad this has never happened to me. Once again AutoCad doesn't disappoint in being very surprising. Have you tried doing a 'Select All' (Ctrl+A) to see if it gets selected? Quote
Kari H Posted September 11, 2009 Author Posted September 11, 2009 Ok, I tried the Crtl A.. no it did not show grips for the "Viewport" Quote
cpriedel Posted September 11, 2009 Posted September 11, 2009 I had that issue once and i saved and closed the drawing. After reopening everything was back to normal. Havent really looked into it since it resolved itself. Maybe reopening is all it takes. Quote
Kari H Posted September 11, 2009 Author Posted September 11, 2009 No this has been opened and closed many times. Quote
ReMark Posted September 11, 2009 Posted September 11, 2009 The color of the viewport border matches the backround. Hence...it cannot be seen. Quote
Kari H Posted September 11, 2009 Author Posted September 11, 2009 No, the grips would still show up. Also, it's an aerial photo so the color varies. Quote
ReMark Posted September 11, 2009 Posted September 11, 2009 A non-selectable viewport. Hmmm....interesting. Is there a Defpoints layer? Quote
Kari H Posted September 11, 2009 Author Posted September 11, 2009 Yes there is a Defpoints layer. It is not frozen or turned off? Quote
Kari H Posted September 11, 2009 Author Posted September 11, 2009 I FOUND IT! We have filters in our drawings. And for some reason a layer wasn't showing up in one filter but did show up in all. Anyway, it was the VP Freeze that was frozen. Thank you all for the help!! Quote
ReMark Posted September 11, 2009 Posted September 11, 2009 Kari: Glad to hear you found the cause of your little problem. Thank you for updating us. Quote
