Is it possible to have different linetype scales on the same line in different viewports in autocad 2008lt?
ie: i have a viewport of a map at a 1:2000 scale with a centerline shown at a particular scale. i have another viewport created of a specific area on that map at a scale of 1:50. That centerline is now solid? could the scale on that specfic line be changed for that viewport only?
If I understand you correctly, I think PSLTSCALE = 1 is wwhat you are looking for...
thanks it worked perfect.
however it does not seem to be working in another viewport that has a drawing xref'ed. the xref linetypes change to solid lines?
any ideas?
