YZ Posted September 17, 2009 Posted September 17, 2009 I have read about a tip for reducing PDF size. That is, to publish to DWF and then create the PDF from there. The trouble is, I cannot find the way to create a DWF. The best way I know how is to select "DWF" in "Publish To:" drop-down menu, but even though it goes through the motions, it doesn't create a file. I've read about DWF6.pc3, but I also cannot find that on my machine. AutoCAD HELP didn't help much on this one. Quote
Dipali Posted September 17, 2009 Posted September 17, 2009 In The Plot Dialoguebox, For Printer Select 'autodesk Dwf Wirter For 2d' (its Available With Autocad 2008 & Higher Versions) Quote
YZ Posted September 21, 2009 Author Posted September 21, 2009 Thanks Dipali. I found it an my old 2009 Plotters. I had deleted it when I was trying to cut out unnecessary ones in 2010! So I can plot to DWF now, but they are all separate files. Does anyone know how to publish a set so that multiple sheets can be in the one DWF? Quote
Dipali Posted September 21, 2009 Posted September 21, 2009 In the 'publish' diloguebox there is a tab ' publish options' click on it & in that second dialguebox choose dwf type as 'multisheet dwf & set relavent options like the file name & location as you wish. Quote
