Problem with text when saving from Autocad 2009 to 2005
I'm using version 2009, but I need to save down to 2005. When I open the drawing in version 2005, my text is not appearing in the right location. Any help...?
It may have something to do with the system variable Savefidelity. Take a look in Help.
Well, my system variable for save fidelity is set as 1 and the save fidelity in my options panel is turned on, but I figured this out...when I explode my mline text and then save it as '05, the texts stays where it's supposed to. It's annoying for someone else to have to work with single line text though. Any thoughts on how not to have to explode your mline text to make this work?
  • 3 years later...
Hello, I'm facing almost the same issue.
I've Autocad Architecture 2013, it works fine until I open the drawing in another PC which has Autocad 2007, Or my own PC with Autocad 2008 (which I installed to check for this issue only). In both earlier version, all the text and dimension styles changes automatically.
I searched the forum, somewhere it is told to make the same fonts in textstyles in both the computers/versions. It is not helping though.
