Is there a way to set an embedded block to match the orientation of the layout? Or lock the orientation of a specific block?
For example, I have triangle block inside of a square block. What I'd like to do is rotate the square block, but have the triangle always right-side up.
I've tried making the triangle block annotative with "match orientation to layout" set but with no luck. The triangle will flip right-side up if I explode the square block, but I'd like to not have to do that.
Have to tried creating them as separate blocks and combining them as a group? Not the best solution, but it's an idea. Could be accomplished with a little code.
Thanks for the suggestion, but with groups I won't be able to insert the final block (square + triangle) into another drawing.
On to code.
