Hi,
I need help, when i create a new dwg using the acad3D.dwt i see the view grey with a 3diemndinal lines etc. if i have a regular dwg and i want to activate that view the 3d grey color with the 3dimensional view using the menu or the ribbon not the workspace option at the right corner what i have to do?
because right now if i select the 3d workspace i see only a 2d black screen.
You can make AutoCAD default to the acadiso3D.dwt when opening a new drawing simply by doing the following.
Tools > Options > Display tab. Click on the Colors button. At the next window select either 3D parallel projection or 3D prespective projection. Click on the Apply & Close button. Finally, click on the OK button. Open a new drawing and notice what AutoCAD now defaults to.
After thinking about this I'm not 100% sure it's going to work. Please let me know one way or the other. I need to think on it a bit more.
hi thanks but i cant do that because i use my cad more for 2d, i know i can select something on the menu or ribbon to activate the 3dimensional space grey with the lines etc and the cube at the top right cornner but i cant remember wheres i saw that on a viedeo online but i cant find the video.
I got the impression you wanted to set this environment as your standard for every new drawing. Not so I see.
no, let me see if i can explain this more simple.
ok i open my empty dwg regular 2d ok and i select my 3d workspace on y bottom right cornner of my autocad ok everything change to 3d workspace except the view, i see the regular black screen for 2d, i want to see the grey 3dimensional workspace with the cube etc. i know i can switch from 2d to 3d in the same workspace but i cant find how.
ok i got it, wow after a day finally i found it, was a very simple things but is you dont know what you are looking can take a day here is the deal.
i had to change in 3d workspace / home tab / 2d wireframe to realistic and then activate the grids with f7.
thats all, wow a day for that simple thing but thatks for your help any way.
You're right...it was simple. Sometimes we can't see the forest for the trees. LOL Thanks for updating us.
yes i decide to post the solution because i am sure i am not going to be the only one with that problem.
  • 7 months later...
urgh. so frustrating (i had the opposite problem, couln't get out of grey 3d screen no matter what i tried)
THANKYOU for posting your solution. xx
