Imprinting 2D objects on a 3d face .
Being very new to all that I've learned this season , I often get things to work and then I can't repeat the same function . For example , I'm learning to edit solid modeling at the moment . I drew a circle on a face of a 3D object , imprinted it and extruded it as instructed . That worked out fine , but when I went to a different face and drew a rectangle to imprint and extrude . I couldn't get the rectangle to attach to the point on the face that I wanted , it ends up being placed off the mark . Could someone please explain what I'm messing up . Thanks
Is your Dynamic UCS on?
You could also re-orient your USC on the plane your trying to draw the object.
Maybe you could post a screen shot so we can better visualize what is happening.
KC
