i have bounced this one around the office and had not real answer so its your turn
i have attached a copy of the dynamic cut line block we are using
so the question:
when using the block you have a letter at each end so have 2 attributes saying the same is there anyway for setting it up so that you only enter the cut line suffix once and it appear at both ends ???
i did find that i could enter a field in Mtext to read the value of the attribute but this only set the field to the default setting and didnt change if the value did
many thanks
Adam
CAD-BLK-01 Cut Line.dwg
after you changed the value did you regen or do a qsave or a fieldupdate the fields dont automatically update with the change but these above will cause them to update
How about putting letters from A to say H and add visibility states to the dynamic block?
When using, you type nothing -choose the desired letter from the drop-down list.
  • 2 weeks later...
tryed all the above and the field just shows the default vaule of the attribue
any one else got any ideas ¿
how did you go about creating the block with a field?
i created Mtext and inserted a Field (Ctrl+f)
Is this just text or is it a block attribute?
well i is just a text field so is set by the drawing not manualy like a attribute if that makes sence
So the text is not part of a block then?
I attached something similar to what you attached with working fields, is this what you are after?
Drawing1.dwg
  • 2 weeks later...
spot on thats exactly what i want
but i cant get it to work inside a block with an attribute any ideas
  • 1 month later...
i think i have done it had to use a block in a block but got it to work you can now edit the attribute of the cutline regen and both are adjusted
:D
