papagyi Posted June 29, 2008 Posted June 29, 2008 Hi, I want to share for some useful system variables which is helpful for working! Pls let share all member. 1st...DEFAULTLIGHTINGTYPE..(0,1).....you can set default one light or two light for rendering with without user light! 2nd..lightingunits..(0,1,2)...0 is generic light and 1,2 for photometric light! 3nd..sunstatus.....(0,1).....Sun..on/off 4th..Dimscale.......user value...you can ajust your current dim style "over all scale" another...coming soon. Quote
papagyi Posted July 1, 2008 Author Posted July 1, 2008 DEFAULTLIGHTING---(0,1)0---Default lighting is automatically turned off when point lights, spotlights, distant lights, or the sun are on 1----Default lighting only is turned on LIGHTSINBLOCKS---(0,1) 0----(off)--Lights in blocks are disabled 1----(on)--Lights in blocks are enabled Quote
papagyi Posted July 6, 2008 Author Posted July 6, 2008 This is new variable of acad2009! Menubar..(0,1).....menu bar ON/Off. When you open acad 2009,you will lost menu bar coz "menubar" is set to "0". You can see menu bar by set to "1". Quote
papagyi Posted August 10, 2008 Author Posted August 10, 2008 You don't want to see ribbon,you can type "ribbonclose". delobj ...(0/1) ....when extrude,source object remain or delet. Quote
papagyi Posted August 26, 2008 Author Posted August 26, 2008 Sometimes we can't open multiple drawings and only open single drawing. You can solve about this by...."SDI" value are (0 and 1). SDI means..single drawing interface. Quote
papagyi Posted September 15, 2008 Author Posted September 15, 2008 Me too!I love "dashboard".I don't understand why they use ribbon instead of dashboard in acad 2009! Quote
