chulse Posted September 29, 2009 Posted September 29, 2009 How could I return the total number of layout labs in a given dwg with lisp? Is it possible to do the same with Diesel? Thanks Quote
SteveK Posted September 29, 2009 Posted September 29, 2009 Hi, Would this work for you: (length (layoutlist)) Not sure about Diesel. Quote
chulse Posted September 29, 2009 Author Posted September 29, 2009 I'll try it, thanks That would not include the Model tab then, right? Quote
SteveK Posted September 29, 2009 Posted September 29, 2009 yep. Cause if you just type in (layoutlist) it'll return all the names of the layouts (without "model") Quote
SteveK Posted September 29, 2009 Posted September 29, 2009 No worries. Do you require it in Diesel for fields? Cause I'd be interested to know that too... Quote
chulse Posted September 29, 2009 Author Posted September 29, 2009 Yeah, that's what started me wondering. I'd like to automate my titleblock with a field (with diesel). I just have no idea how. Quote
chulse Posted September 29, 2009 Author Posted September 29, 2009 Does anyone know how to do this with Diesel? Please? Quote
Lee Mac Posted September 29, 2009 Posted September 29, 2009 Does anyone know how to do this with Diesel? Please? I'm not sure that you can - (layoutlist) itself is an Arx function, and the number is not stored in any Sys Var, so DIESEL is pretty difficult for this task. I'd be intrigued if someone provided DIESEL code to accomplish such a task. Quote
alanjt Posted September 29, 2009 Posted September 29, 2009 I'm not sure that you can - (layoutlist) itself is an Arx function, and the number is not stored in any Sys Var, so DIESEL is pretty difficult for this task. I'd be intrigued if someone provided DIESEL code to accomplish such a task. Could if you were using 07. You could use lisp functions in fields. You can access 'lisp variables' now, why not just give us the option to use short lisp functions. Quote
chulse Posted September 29, 2009 Author Posted September 29, 2009 Could if you were using 07. You could use lisp functions in fields. You can access 'lisp variables' now, why not just give us the option to use short lisp functions. I can't believe they would remove that functionality. (...well ok, yes I can...) Quote
alanjt Posted September 29, 2009 Posted September 29, 2009 I can't believe they would remove that functionality. (...well ok, yes I can...) I think it was a bug. We went from 06 to 08, so I only heard about it. Quote
SteveK Posted September 30, 2009 Posted September 30, 2009 Could if you were using 07. You could use lisp functions in fields. You can access 'lisp variables' now, why not just give us the option to use short lisp functions. I'd like to know how to you use a lisp function within a field; In the fields table I can only see LispVariable and I'm thinking if you assign a variable (eg (length (layoutlist))), you'd still have to initialize the lisp program at the start of each session... which a client wouldn't like.... but if there's somewhere where fields support lisp functions then we're in business! But is there...? Quote
ronjonp Posted October 1, 2009 Posted October 1, 2009 I'd like to know how to you use a lisp function within a field;In the fields table I can only see LispVariable and I'm thinking if you assign a variable (eg (length (layoutlist))), you'd still have to initialize the lisp program at the start of each session... which a client wouldn't like.... but if there's somewhere where fields support lisp functions then we're in business! But is there...? Perhaps in the making....http://www.theswamp.org/index.php?topic=30471.0 Quote
SteveK Posted October 1, 2009 Posted October 1, 2009 Perhaps in the making....http://www.theswamp.org/index.php?topic=30471.0 Yeah I think a fair few people are waiting to see Andrea's code... Still, won't we need to run the lisp program to get the Mlisp to function? (fine for us, but not for clients) Quote
chulse Posted October 1, 2009 Author Posted October 1, 2009 Yeah I think a fair few people are waiting to see Andrea's code... Still, won't we need to run the lisp program to get the Mlisp to function? (fine for us, but not for clients) Well, I only send PDFs to clients, so it will work wonders for me Quote
SteveK Posted October 1, 2009 Posted October 1, 2009 Well, I only send PDFs to clients, so it will work wonders for me Hi Cary, But then why not just assign a user variable to a field (eg userr1), then just before you pdf you update the variable with: (setvar "userr1" (length(layoutlist))) or any variable (setq numLays (length(layoutlist))) Quote
alanjt Posted October 1, 2009 Posted October 1, 2009 Hi Cary,But then why not just assign a user variable to a field (eg userr1), then just before you pdf you update the variable with: (setq userr1 (length(layoutlist))) Hmm (if (not *CommandReactors-PlotSheetCount*) (setq *CommandReactors-PlotSheetCount* (vlr-command-reactor nil '((:vlr-commandWillStart . StrtCMD-PlotSheetCount) ) ) ;_ vlr-command-reactor ) ;_ setq ) ;_ if (defun StrtCMD-PlotSheetCount (calling-reactor StrtCMD-PlotSheetCountInfo / theCMDStrt) (setq theCMDStrt (strcase (car StrtCMD-PlotSheetCountInfo))) (cond ((wcmatch theCMDStrt "*PLOT*,*PUBLISH*") (setvar "userr1" (length (layoutlist))) ) ) ;_ cond ) ;_ defun Quote
CADMASTER1128 Posted October 1, 2009 Posted October 1, 2009 Hi,Would this work for you: (length (layoutlist)) Not sure about Diesel. Nice an useful code there! Thanks for that. Quote
SteveK Posted October 1, 2009 Posted October 1, 2009 Hmm (if (not *CommandReactors-PlotSheetCount*) (setq *CommandReactors-PlotSheetCount* (vlr-command-reactor nil '((:vlr-commandWillStart . StrtCMD-PlotSheetCount) ) ) ;_ vlr-command-reactor ) ;_ setq ) ;_ if (defun StrtCMD-PlotSheetCount (calling-reactor StrtCMD-PlotSheetCountInfo / theCMDStrt) (setq theCMDStrt (strcase (car StrtCMD-PlotSheetCountInfo))) (cond ((wcmatch theCMDStrt "*PLOT*,*PUBLISH*") (setvar "userr1" (length (layoutlist))) ) ) ;_ cond ) ;_ defun Yeah I like that Alan. Because then you can add other variables to it that might be referenced in other fields. Plus, having it in your startup you don't need to worry about updating before pdf'ing. Quote
