That said, I'm beginning to wonder whether to cut out the middle man (fields). Using Alan's code, if you know the block and tag, why bother with fields! Faster? :huh:
  • Replies 37
  • alanjt
    12
  • SteveK
    11
  • chulse
    7
  • Fatrus
    3
I'd still default the total pages attribute with a diesel expression field $(getvar,userr1), that way you can use it on any style titleblock.
True. .
I forgot, it needs to be a string, not a real number, try this:
(vl-load-com)
(if (not *CommandReactors-PlotSheetCount*)
 (setq *CommandReactors-PlotSheetCount*
        (vlr-command-reactor
          nil
          '((:vlr-commandWillStart . StrtCMD-PlotSheetCount)
        ) ;_ vlr-command-reactor
 ) ;_ setq
) ;_ if
(defun StrtCMD-PlotSheetCount
      (calling-reactor StrtCMD-PlotSheetCountInfo / theCMDStrt)
 (setq theCMDStrt (strcase (car StrtCMD-PlotSheetCountInfo)))
 (cond
   ((wcmatch theCMDStrt "*PLOT*,*PUBLISH*")
    (setvar "users1" (vl-princ-to-string (length (layoutlist))))
 ) ;_ cond
) ;_ defun
and call it by Diesel with $(getvar,users1)
(vl-load-com)
          nil
 ) ;_ setq
) ;_ if
 (cond
    (setvar "[color=Blue]users1[/color]" (vl-princ-to-string (length (layoutlist))))
 ) ;_ cond
) ;_ defun
Three things;
- I think it's userr1 not users1
- why does it need to be a string? Real & integers seem to be recognized in fields.
- and lastly, I've been using a LispVariable but now that I look for userrX system variables I can't find them in the list within the field table...?
Three things;
userr# is for real numbers
useri# is for integers
users# is for strings
Attributes need strings.
Since it's not technically a system variable, it's probably ignored. Calling it with Diesel should work.
This is all proof of concept, I've not had a chance to test it.
SUCCESS! I just tried it and it works perfectly. Here's an update with the addition of the Preview command.
          nil
 ) ;_ setq
) ;_ if
 (cond
   ((wcmatch theCMDStrt "*PLOT*,*PUBLISH*,*PREVIEW*")
 ) ;_ cond
) ;_ defun
Here the example I used, just a piece of MText:
Total Layouts: %<\AcDiesel $(getvar,users1)>%
Sorry I should have looked at those sysvariables a bit closer.
Indeed, it works well! Thanks Alan. And preview is a good addition.
No problem. I really like this, I'll be incorporating this into my sheets from now on.
Here it is using a Lisp variable, instead utilizing the user*# variables. I think this is a better option:
Example:
Total Layouts: %<\AcVar.17.0 Lisp.plotsheetcount:value>%
The reason I have it setq it, on startup, as "", is to enable the user to select the variable in the Field Lisp Variable list.
Code updated and move here: http://www.cadtutor.net/forum/showthread.php?t=40653
hoook! Hi to all!
Right now Im trying to do that... and I just dont know where to put this code.....? can someone could show me where to past this... or just send me to a post in the forum...
Tks a lot!!!
hoook! Hi to all!
Tks a lot!!!
Save the file then appload or put posted load code in acaddoc.lsp file (I posted info. for this option in the other thread).
..sorry i dont get it.. Im not very good in lisp diesel thing...
im talking about your big code....
and tks for your reply ;)
No problem. :)
Probably the best thing is to put the lisp in a directory and type appload then load it into the Startup Suite (briefcase at bottom).
Look here, if you still need help, give a shout:
http://www.cadtutor.net/faq/questions/28/How+do+I+use+an+AutoLISP+routine%3F
http://www.cadtutor.net/faq/questions/53/How+do+I+automatically+load+variables%3F
cool tanks... and if I send the drawing to someone else, did he need the lisp?
I'm not telling you to send anything, but it won't work without it.
  • 3 years later...
          nil
 ) ;_ setq
) ;_ if
 (cond
 ) ;_ cond
) ;_ defun
Hi Alan, I tried to use this code by copying and pasting to a text file storing the one lsp extension, when I enter the command autocad APPLOAD use to read the new lisp, lisp when reading this message appears:
APPLOAD tabs.lsp number successfully loaded.
Command:, error: invalid reaction name: VLR-COMMANDWILLSTART
I ask you please tell me what to do, could you help me, please. As not load the lisp then there if you really active command is this "plotsheetcount" I think this is the command but I have not so clear.
Excuse my bad grammar I speak Spanish and my English is very poor.
Greetings.
Try entering this at the Command Line, and try Alan's code again:
(vl-load-com)
