Doughs Posted September 29, 2009 Posted September 29, 2009 Drawing in model space all the lineweights when I "list" are at 0.7mm: when i check Lineweight settings they are set to default which is 0.25mm: The drawings are then plotting to the 0.7mm lineweight which is obviously too thick: I've tried changing lineweights in "Layers" and Lineweight Settings and different plotting settings but to no avail: How do i get back to 0.25mm default or equivalent to allow me to achieve proper lineweight plots... help--it's driving me over the edge thanks Doug (up until a few days ago all was ok--I have inadvertantly changes settings or similar somewhere!!) Quote
NBC Posted September 29, 2009 Posted September 29, 2009 can you post here what you get when you list something in model space ? Quote
Doughs Posted September 29, 2009 Author Posted September 29, 2009 "List" response ref lineweights Select objects: LINE Layer: "WALLS" Space: Model space LineWeight: 0.70 mm Linetype scaling = 400.0000 Handle = 338e8 from point, X=25582.4382 Y=11052.8664 Z= 0.0000 to point, X=25582.4382 Y=19940.9226 Z= 0.0000 Length =8888.0562, Angle in XY Plane = 90 Delta X = 0.0000, Delta Y = 8888.0562, Delta Z = 0.0000 Quote
NBC Posted September 29, 2009 Posted September 29, 2009 Ok thanks for the prompt reply. At the commandline, type QSELECT In the box that appears, select Multiple, then Lineweight, then 0.70mm in the Value. Press OK. Open the Properties Palette, and using the Lineweight dropdown, scroll to the desired Lineweight setting. Quote
Doughs Posted September 29, 2009 Author Posted September 29, 2009 thanks NBC.. got plots that are legible now.. (blocks seemed to be a bit of an issue--had to explode them) thanks again Doug Quote
