Random lines to viewport corner appear in Plot
For starters, I am working in Civil 3D 2009 LD with a drawing which contains a topo with elements not saved by AutoDesk products. Here is what happens: When I plot in paper space, I get mysterious lines coming out of a point and heading to the corner of my viewport. If I resize the viewport shape, the direction of the lines changes to the new corner. If there is no dview Twist in the model space paper space, then the lines don't appear. With dview TWIST or UCS rotation the lines go to the corner of the viewport. The lines do not appear in the plot preview with the UCS in World and with no DVIEW TWist. They only appear in the print preview and on the actual plot when a Twist is applied. Any suggestions would be appreciated.
  • 9 months later...
I know it's been a while, but did you ever find out the issue with your drawing? I think I'm having the same problem...
