printting date to be change by automaticaly
Dear gys,
I wan to do some title block template. So in that I need put date when it print that time printed date to be change by automaticaly
I know that posible. (last company i was work they are use that please halp me for this)
this field is correct but not work
Can you tell us what doesn't work, any error messages you get when you try it, any screenshots, etc ?
I daon't want Plot stamp that not part of my titile.
& no massage coming show ---- like that when i print also same
The Plot Stamp dialog box has a section for User defined fields (that's you). PlotDate can be a user defined field.
There is no "message" for the Plot Stamp feature. It is a check-off box under Plot Options (Plot Stamp on). There is an Edit button right next to it when the option is enabled. All this can be found on the Plot dialog window.
hear with I attached this file If you can help me
thanks lot, Actualy I dont like plot stamp if some one need to off the stamp it can so that not suit for me
Test.dwg
There appears nothing 'wrong' with the file you attached.
The reason you are not seeing what you hoped you would see in the plot date field, is because the file has not been plotted yet
thanks NBC & ReMark before I check this but is not work that time But now i did as new drawing same test file it's work so thank for both
