How can I make an arc leader line versus a straight or spline line? I have gone into Leader Settings but do not see any options that create an arc leader.
I'm pretty sure you can only create straight lines and splines. You could make a spline look like an arc.
can you show us a screen shot of what your wanting the final outcome to be
Unfortunately, I do not have a screen shot. I saw the arc on a competitors drawing and it gives a "clean" look. After further research I was told you can purchase an "add-on" called LeaderM8 which will give you the arc option. It looks like it's only compatible for 2000-2009 versions though. Hopefully, it will be available for 2010 soon.
Qleader > Settings... there is an option for Spline
or create a Multileader style using the spline option (Mleaderstyle)
You are on 2010 so I would move to Mleaders, set up the different styles in a template, etc.
