mikman Posted July 8, 2008 Share Posted July 8, 2008 Hey all, I am wanting to just get real picky with what I am doing. I am trying to have a lisp routine run with a prompt telling me that it finished but I want it to be in a different color that the text in my command line. Is this possible? I couldn't find any comments on it anywhere. (defun C:osm () (command "osmode" "163") (prompt "Object Snap Mode is set to Meikle") (prin1) ) Here is an example, I'm new at this so it is really simple, but hey you gotta start somewhere! Any ideas can only help! Thanks all! Quote Link to comment Share on other sites More sharing options...
CAB Posted July 8, 2008 Share Posted July 8, 2008 No ideas for color but for something different try (alert "Object Snap Mode is set to Meikle") Quote Link to comment Share on other sites More sharing options...
mikman Posted July 8, 2008 Author Share Posted July 8, 2008 Thanks I used that and it works just as well as changing the color. Quote Link to comment Share on other sites More sharing options...
ASMI Posted July 8, 2008 Share Posted July 8, 2008 (vl-load-com) (defun #Asmi_Cmd_Line_ForeColor(Color / Col) (if(setq Col(cdr(assoc(strcase Color) '(("WHITE" . 16777215)("BLACK" . 2) ("RED" . 255)("YELLOW" . 65535) ("GREEN" . 65280)("CYAN" . 16776960) ("BLUE". 16711680)("MAGENTA". 16711935))))) (vla-put-TextWinTextColor (vla-get-Display (vla-get-Preferences (vlax-get-acad-object))) (vlax-make-variant Col 19)) ); end if (princ) ); end of #Asmi_Cmd_Line_ForeColor (defun #Asmi_Cmd_Line_BackColor(Color / Col) (if(setq Col(cdr(assoc(strcase Color) '(("WHITE" . 16777215)("BLACK" . 2) ("RED" . 255)("YELLOW" . 65535) ("GREEN" . 65280)("CYAN" . 16776960) ("BLUE". 16711680)("MAGENTA". 16711935))))) (vla-put-TextWinBackgrndColor (vla-get-Display (vla-get-Preferences (vlax-get-acad-object))) (vlax-make-variant Col 19)) ); end if (princ) ); end of #Asmi_Cmd_Line_BackColor Usage example: (#Asmi_Cmd_Line_ForeColor "red") ; to set red font (#Asmi_Cmd_Line_BackColor "black") ; to set black background > CAB Tip! BackColor = ForeColor and NOMUTT no need! Quote Link to comment Share on other sites More sharing options...
CAB Posted July 8, 2008 Share Posted July 8, 2008 Learn something every day. Thanks ASMI Quote Link to comment Share on other sites More sharing options...
mikman Posted August 12, 2008 Author Share Posted August 12, 2008 Alright so I am back now with another question about lisp and text. I was recently using a lisp that added up text in the drawing I was working in. I stopped working and qutoed "mktext" as the problem. I can't modify the routine, its locked and the owner doesn't work with me anymore. Where can I find a place that would have a lisp that I could read and learn for myself? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 12, 2008 Share Posted August 12, 2008 You say the routine added up text... Did the routine sum the value of text strings that were numerical? BTW, you might want to start a new thread with a new topic heading... Quote Link to comment Share on other sites More sharing options...
mikman Posted August 12, 2008 Author Share Posted August 12, 2008 I started a new thread, thanks. And ya the strings were numerical. Quote Link to comment Share on other sites More sharing options...
