Hello
I am trying to copy a view of my drawing from one layout tab to another. I have been doing this using copy and paste which works OK, the problem I'm having is that the dimensions i have added to the layout in paper space are not copying with the rest of the object, is this possible or not? I have selected the display viewport objects option to yes and this brings up the drawing but not the dimensions.
I am using auto cad version 2007.
Thanks Jaseb
When you copy and paste, the only things that will be copied are the things you have selected. So, when you select the viewport to copy, are you selecting the dimensions also? It sounds like you are only selecting the viewport?
I was only selecting the viewport.:oops:
Thanks for that works fine now.
Jaseb
