p1nkninja Posted October 4, 2009 Posted October 4, 2009 Right, hello smart ones! I need help, help, heeelp. I am trying to improve my skills on the whole new autocad. I found it rather easy to add muntins to windows: where you can just go to create a window from Tool palettes > Right Click on windows > Window styles > Display Properties > Style Override the model > Muntins > Add > and play around with the options. When I tried to add muntins to a door, it just wont work Thanks in advance Quote
Tommy78 Posted October 5, 2009 Posted October 5, 2009 Excuse my ignorance, but what are muntins?! Quote
Currahee Posted October 5, 2009 Posted October 5, 2009 Right, hello smart ones! I need help, help, heeelp. I am trying to improve my skills on the whole new autocad. I found it rather easy to add muntins to windows: where you can just go to create a window from Tool palettes > Right Click on windows > Window styles > Display Properties > Style Override the model > Muntins > Add > and play around with the options. When I tried to add muntins to a door, it just wont work Thanks in advance Are you sure you clicked the style override in the right Display Representation (Plan, Model, Elevation...etc)? It should work...looks like you done everything correct. Quote
ReMark Posted October 5, 2009 Posted October 5, 2009 Tommy78: "Muntin is a strip of wood or metal separating and holding panes of glass in a window." Source: Wikipedia Quote
Tommy78 Posted October 6, 2009 Posted October 6, 2009 Tommy78: "Muntin is a strip of wood or metal separating and holding panes of glass in a window." Source: Wikipedia Thanks, i'm not native English and couldn't find it in the first dictionary that google suggested so was a bit clueless :wink:. Quote
DODGE Posted October 6, 2009 Posted October 6, 2009 There ya go. I just learnt something also. Ithought he was talking about mullions. Just shows ya never too old to learn. D Quote
Tommy78 Posted October 6, 2009 Posted October 6, 2009 There ya go. I just learnt something also.Ithought he was talking about mullions. Just shows ya never too old to learn. D Wikipedia: A mullion is a structural element which divides adjacent window units[1]. Mullions may be made of any material, but wood and aluminum[2] are most common, although stone is also used between windows. Mullions are vertical elements and are often confused with transoms, which lie horizontally. The word is also confused with the "muntin" (or "glazing bar" in the UK) which is the precise word for the very small strips of wood or metal that divide a sash into smaller glass "panes" or "lites". Crickey!, that's 2 new words i learnt today. Quote
ReMark Posted October 6, 2009 Posted October 6, 2009 Where do we sign up for the architectural terminology class? LOL Quote
p1nkninja Posted October 13, 2009 Author Posted October 13, 2009 Lol, I figured out how to do it!! For those of you who had a similar problem.. All you have to do is the following: First import a similar door you'd like. How to do that? - Under Design Palette, go to Doors, right-click on the desired door> Import - Then follow the steps below: 1. Right-click on the door in your modelspace. 2. Click on 'Edit Door Style' 3. Click on 'Design Rules' > Click 'Use Profile' > pull down menu and choose the door style you imported. Now if you go to 'Design Properties' > Elevation > Muntins > Add. You will be able to add muntins YAAAAY!! Perhaps there are other ways, but that way worked like magic for me! Quote
Tankman Posted October 13, 2009 Posted October 13, 2009 Easy enough. Add molding to the window. What's the problem? Quote
