GCtech Industries Posted July 9, 2008 Share Posted July 9, 2008 Hello Everyone My name is Gilbert im new around here:) this forum is awsome! Im having some issues with a model im working on in Solidworks , I am a new user I have been able to create several parts with no trouble, but this one in particular I lost it What im drwaing in a 4-1 collector 1.9''OD .145'' wall round tube ,the problem is when is time to assamble the 4 parts together , when I assamble the 4th tube is the problem , is off on the measurments it does not fit properly , I have try to play with the end dimentions but no luck. I can email u the SW file so u get a better Idea what im trying to explain thanks for any help provided I apreciate it. Gilbert Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 9, 2008 Share Posted July 9, 2008 Zip and attach the file here. Roll up the feature tree before zipping. Quote Link to comment Share on other sites More sharing options...
GCtech Industries Posted July 9, 2008 Author Share Posted July 9, 2008 Here they are thanks! Gil Assem1.zip collector cut.zip Quote Link to comment Share on other sites More sharing options...
solidvictor Posted September 5, 2008 Share Posted September 5, 2008 It is better, modeling the parts such a way that, assembling will be easier, especially like this case. First decide the angle between axis of the 4 tubes and central axis of the assembly. Model the tube as if it is in the assembly position and assemble it. Here with I have attached the Model & Assembly I have created for your requirement. I hope it is enough for your need. Assem2.zip collector cut2.zip Quote Link to comment Share on other sites More sharing options...
