Delete all hatches within a drawing?
We're in agreement for Best Practices... I simply included this functionality in response to the OP's explicit request of how to 'Delete all hatches in a drawing?'
I do use routines which *add* entities to a given drawing regardless of locked layers; but I cannot think of a practical, non-one-time-use as I *believe* this thread's purpose to be.
That's a completely different situation and unlike vla-add*, entmake doesn't care if the layer you are creating objects on is locked.
BTW, bear in mind (I just noticed this), this thread is in the beginner's section.
Link to post
  • Replies 25
  • alanjt
    6
  • BlackBox
    5
  • nicolas
    3
  • Mr.Alex
    2
Posted Images
Hi,
I do understand that quick select (qselect or simply qs using a personal alias name) is a top tools to quickly delete all hatches or all hatches using such and such patterns and the combinations are numerous based on object properties.
However as a autolisp newbie, I would like to implement something similar to quick select in autolisp and I know that given qselect is a dialog box, I can't use it. I know nothing of visual lisp except the vl-load stuff.
Is there a way to implement ssx or filter or any other command to autolisp. Suppose I want to delete or isolate or set to hidden mode all the solid hatches at once. I know I can use qselect but being able to use autolisp is even more powerful for it can be apply to any object, any properties and I do believe that we can used boolean operator as well.
Regards,
Nicolas.
Link to post
BlackBox
Alan's right - as this is the beginner's area, perhaps your question would be better answered from the AutoLISP, Visual LISP & DCL forum.
Link to post
Here's a very simple example of selecting all hatch:
(ssget "_X" ; select all of something
      '((0 . "HATCH") ; hatch object
        (8 . "PIZZA") ; on layer "PIZZA"
        (2 . "ANSI32") ; pattern name "ANSI32"
Literature on DXF codes:
http://docs.autodesk.com/ACD/2011/ENU/filesDXF/WSfacf1429558a55de185c428100849a0ab7-5f35.htm
http://images.autodesk.com/adsk/files/acad_dxf2.pdf
Link to post
BlackBox
(8 . "PIZZA") ; on layer "[color=red]PIZZA[/color]"
Awww, man... now I'm hungry. :glare:
Link to post
