what version of autocad you are using ?? am using 2007
anyway thanks a lot :)
  • Replies 31
  • noorb
    9
  • ReMark
    7
  • gil9166
    4
  • tzframpton
    2
I'm using 2012.
You could always use QSELECT then follow this up with the CHANGE command and the Color option.
i tried this way but it takes too much time ! i loved this lisp but it doesn't work for me ..
is there anyway to modify it so we can use it in autocad 2007 ??
thanks
Post a copy of your drawing in 2000 format and I will test the LISP in 2000 when I get home this evening.
hello ,
the drawing is too big so i deleted most of it , anyway the layer i want to change is RE-PROFILE-TEXT the mtext is in the yellow and pink and green colors , i want them to be bylayer .. but when i used the lisp attached in this thread it didn't work for me it eats the last character of the text ..
if you can help me with this i will be appreciated :))
thanks so much
J08086-CNS-PA5-AB-ENV-WW-001 TO 005.zip
i used the link attached above but unfortunately it didn't work ! what i need to do is to change the color of the mtext's text to bylayer instead of picking each mtext and change the color in the text's edit
  • 2 years later...
Hi there guys ,
first thank you to the creator of the CMtext.lisp program it has helped me a few times in layouts from architects where the text would not change color to by layer.
i would like to ask if anyone is having a problem with the cmtxt.lisp where after running it the last letter in the mtext object is missing eg . House would then be Hous .
can any one help me please.
regards
