muck Posted October 12, 2009 Posted October 12, 2009 Version 2009, I have only ribbons shown on my menu and I don't see a command line. How do I get my command line and get rid of those ribbons with menus? Thank you, Quote
Tiger Posted October 12, 2009 Posted October 12, 2009 well, to get your commandline back, you should be able to type COMMANDLINE (COMMANDLINEHIDE to hide it) and it should come up- don't worry that you type something without it showing, just type it and hit enter. To get rid of the Ribbon, beside that I would recommend trying to get used to it (for one thing, the Office-package uses it, mind as well get used to it), there are a way to return to the previous look, I have read it here multiple times so try to serch for ribbon on here and you should find it. Quote
ReMark Posted October 12, 2009 Posted October 12, 2009 The Ribbon can be replaced with drop-down menus using the MENUBAR command. I believe it should be set to "1". Quote
muck Posted October 12, 2009 Author Posted October 12, 2009 Problem solved. Thanks for quick responce. Quote
