Lucas_ Posted July 14, 2008 Posted July 14, 2008 Hey !! I wounder why I only can attach xref like a full patch only and not like a relative patch ? I already have 2 xref added in relative patch mode but I need to add one more. //Thanks for all help Quote
Tiger Posted July 14, 2008 Posted July 14, 2008 As far as I know, you have to first attach the X-ref and then alter the path to Relative after it's attached. I've never done it another way anyways. Quote
chulse Posted July 14, 2008 Posted July 14, 2008 I know you need to save the dwg befor you can attach an xref with a relative path. Otherwise it will force a full path. Tiger- How do you change the path type after the xref is attached? I didn't know you could do that... Quote
Tiger Posted July 14, 2008 Posted July 14, 2008 I just noticed that you could select Path Type when attaaching the X-ref.. never used that option but there you have it - if (as chulse says) the drawing is saved beforehand. To change a Full Path to Relative I bring out the XRef Manager, highlight the X-ref in question and under Details you can change the path under 'Found At', add some dots and slashes in the right order and voila! Quote
chulse Posted July 14, 2008 Posted July 14, 2008 I just noticed that you could select Path Type when attaaching the X-ref.. never used that option but there you have it - if (as chulse says) the drawing is saved beforehand. To change a Full Path to Relative I bring out the XRef Manager, highlight the X-ref in question and under Details you can change the path under 'Found At', add some dots and slashes in the right order and voila! Nice. Thanks! Quote
rkmcswain Posted October 30, 2008 Posted October 30, 2008 As far as I know, you have to first attach the X-ref and then alter the path to Relative after it's attached. I've never done it another way anyways. No, not necessarily. There is a bug in AutoCAD that will refuse to allow a relative path sometimes, even when it's technically possible. But the workaround is to save the drawing and try again, it works the second time. (I'm not sure if this has been solved and with what version...) There is also a way to make "relative path" the default setting. See: http://forums.augi.com/showthread.php?t=39723 Quote
