feargt Posted October 13, 2009 Posted October 13, 2009 Hi, Is it possible to reset the standard scale list to the same list that is in our drawing template. Currently if someone uses the scalelistedit command the list of scales does not match our template drawing. I would like to then put this in my acaddoc.lsp file to run each time a drawing opens. Thanks Quote
rkmcswain Posted October 13, 2009 Posted October 13, 2009 Sure. What part do you need help with? Check out the thread below. You may be able to use the lisp code posted (make sure you look for the latest version in that thread), or you might be able to use that code as a starting point for your own code: http://discussion.autodesk.com/forums/thread.jspa?messageID=5685088 Quote
feargt Posted October 13, 2009 Author Posted October 13, 2009 Brilliant just brilliant!.......... I have to slap myself that I did not think of that. Thanks rkmcswain Quote
