Is there any quick way to pdf
You could set auto publish to plot to pdf as seperate files.
All you do is set it up to a specified folder. select pdf plot. plot on close.
Open a drawing and close it again and it will plot all the tabs to the folder you have specified.
Now we are getting deep ha! I feel a serious lack of autocad knowledge compared to you guys.
what do you mean by this
  • Replies 31
  • Nick-H-
    16
  • stevsmith
    6
  • chelsea1307
    5
  • Glen Smith
    3
Posted Images
Auto publish is quite easy to understand.
Try doing the following;
Tools>
Options>
Plot & Publish>
Automatic Publish Settings
Autopublish Options
Publish on = Close
Location = {specify where you want to publish}
Include = {in this case layouts}
General PDF/Dwf Options
File format = PDF
Type = Single Sheet
Layer information = Do not Include
Merge Control = Lines Overwrite
DWF Data options
Cancell all these options.
hit ok and make sure the Automatic publish box is checked.
Click Apply and exit the options menu.
Open a drawing, click save, close the drawing and auto publish will automatically plot all the layout tabs to single files into the directory specified under AutoPublish options as described earlier
I hope, lol...:D
Oh and can I just add that you dont have to have a page setup configuration to do this, eg portrait and landscape. It always prints to extents and rotates the page accordingly.
Tools>
Options>
Plot & Publish>
Autopublish Options
Publish on = Close
File format = PDF
Type = Single Sheet
DWF Data options
I hope, lol...:D
And this will publish a PDF everytime i plot a drawing?
Every time you close a drawing it will print all the tabs to a pdf if you have set it up the way i have shown.
Remember to only open the drawings you need to pdf, if you open a random file, and close it, it will pdf that flie as well.
You may want to set publish on = prompt on close.
that is good think im going to set that up
I cant find that option on my autocad (acad 2007) ive attached a pic of what options ive got
mmm. I would think 2007 had autopublish.
Press f1 to bring up the help menu and do a search for autopublish.
think that came around in 08 or 09
Checked autodesk website and AUTOPUBLISH came out in 2008, seems like 2008 was the year for a bit of an overhaul on publishing ability
I use a program called primo PDf and it seems to work good and fast, but I'v only used it on single PDF's
