Nick-H- Posted October 14, 2009 Author Posted October 14, 2009 You could set auto publish to plot to pdf as seperate files.All you do is set it up to a specified folder. select pdf plot. plot on close. Open a drawing and close it again and it will plot all the tabs to the folder you have specified. Now we are getting deep ha! I feel a serious lack of autocad knowledge compared to you guys. what do you mean by this Quote
stevsmith Posted October 14, 2009 Posted October 14, 2009 Auto publish is quite easy to understand. Try doing the following; Tools> Options> Plot & Publish> Automatic Publish Settings Autopublish Options Publish on = Close Location = {specify where you want to publish} Include = {in this case layouts} General PDF/Dwf Options File format = PDF Type = Single Sheet Layer information = Do not Include Merge Control = Lines Overwrite DWF Data options Cancell all these options. hit ok and make sure the Automatic publish box is checked. Click Apply and exit the options menu. Open a drawing, click save, close the drawing and auto publish will automatically plot all the layout tabs to single files into the directory specified under AutoPublish options as described earlier I hope, lol... Quote
stevsmith Posted October 14, 2009 Posted October 14, 2009 Oh and can I just add that you dont have to have a page setup configuration to do this, eg portrait and landscape. It always prints to extents and rotates the page accordingly. Quote
Nick-H- Posted October 14, 2009 Author Posted October 14, 2009 Auto publish is quite easy to understand.Try doing the following; Tools> Options> Plot & Publish> Automatic Publish Settings Autopublish Options Publish on = Close Location = {specify where you want to publish} Include = {in this case layouts} General PDF/Dwf Options File format = PDF Type = Single Sheet Layer information = Do not Include Merge Control = Lines Overwrite DWF Data options Cancell all these options. hit ok and make sure the Automatic publish box is checked. Click Apply and exit the options menu. Open a drawing, click save, close the drawing and auto publish will automatically plot all the layout tabs to single files into the directory specified under AutoPublish options as described earlier I hope, lol... And this will publish a PDF everytime i plot a drawing? Quote
stevsmith Posted October 14, 2009 Posted October 14, 2009 Every time you close a drawing it will print all the tabs to a pdf if you have set it up the way i have shown. Remember to only open the drawings you need to pdf, if you open a random file, and close it, it will pdf that flie as well. You may want to set publish on = prompt on close. Quote
Nick-H- Posted October 14, 2009 Author Posted October 14, 2009 that is good think im going to set that up Quote
Nick-H- Posted October 15, 2009 Author Posted October 15, 2009 I cant find that option on my autocad (acad 2007) ive attached a pic of what options ive got Quote
stevsmith Posted October 15, 2009 Posted October 15, 2009 mmm. I would think 2007 had autopublish. Press f1 to bring up the help menu and do a search for autopublish. Quote
chelsea1307 Posted October 15, 2009 Posted October 15, 2009 Checked autodesk website and AUTOPUBLISH came out in 2008, seems like 2008 was the year for a bit of an overhaul on publishing ability Quote
wes2017 Posted October 19, 2009 Posted October 19, 2009 I use a program called primo PDf and it seems to work good and fast, but I'v only used it on single PDF's Quote
