SAM_R Posted October 13, 2009 Share Posted October 13, 2009 I'm using Auto Cadd 2008, and in a project I'm working in when I bring in a block from my tool palettes I get this pop up "This application has detected a mixed version of AEC objects participating in this operation. Newer AEC objects will be disallowed from participating in this operation." My question is what are AEC objects and how do I get this to stop coming up? Thank you for any help. Quote Link to comment Share on other sites More sharing options...
Glen Smith Posted October 13, 2009 Share Posted October 13, 2009 AEC objects are apparently created with Autocad Architecture or Autocad MEP. If you have a copy of either of these packages, you have no problems (other than learning to work with those packages). Since you do not have Architecure or MEP, you may be facing a problem. What is the source of the blocks that are causing the problem? Are they in-house blocks? Can you recreate them? I don't see how they could have AEC elements unless they were created with Arch or MEP. Good luck Glen Quote Link to comment Share on other sites More sharing options...
SAM_R Posted October 13, 2009 Author Share Posted October 13, 2009 They are in house blocks. But that warning also comes up if I copy text from another drawing. Quote Link to comment Share on other sites More sharing options...
