The Courage Dog Posted October 14, 2009 Posted October 14, 2009 hi, i have a dynamic block, when i insert it to current drawing the actions are still there, but when rotating the block actions are loosing. Is anybody there who has the idea what was going on on my dynamic block? Thanks you for all your incoming helps. Quote
GE13579 Posted October 14, 2009 Posted October 14, 2009 Can you post the block at all? It's likely that you're not linking all the actions and parameters together right (can be a real headache with dynamic blocks). Quote
gilsoto13 Posted October 14, 2009 Posted October 14, 2009 hi, i have a dynamic block, when i insert it to current drawing the actions are still there, but when rotating the block actions are loosing. Is anybody there who has the idea what was going on on my dynamic block? Thanks you for all your incoming helps. I usually find myself with the same problem... I haven´t go deeply into this problem, but I can solve it easily by sincronizing the block when this happens and voala.. the functions show up again... just use attsync... select block... and done. you can also use a lisp to quickly sincronize selected blocks at once... do you want me to find it for you? You can use this lisp code to synchronize selected blocks, including normal, attributed and dynamic blocks. I've used part of a lisp code from Lee Mac to change selected blocks to current dimscale and then synchronize them... this one just synchronize them. ;Synchronize selected blocks Syb.lsp (defun c:syb (/ *error* doc oldc ss sel) (vl-load-com) (defun *error* (msg) (if doc (vla-EndUndoMark doc)) (if oldc (setvar "CMDECHO" oldc)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n** Error: " msg " **"))) (princ)) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (setq oldc (getvar "CMDECHO")) (setvar "CMDECHO" 0) (prompt "\nSelect Blocks to synchronize... ") (if (setq ss (ssget '((0 . "INSERT")))) (progn (vla-StartUndoMark doc) (vlax-for Obj (setq sel (vla-get-ActiveSelectionSet doc)) (if (eq :vlax-true (vla-get-HasAttributes Obj)) (command "_.attsync" "_Name" (vlax-get-property Obj (if (eq :vlax-true (vla-get-isDynamicBlock Obj)) 'EffectiveName 'Name))))) (vla-delete sel) (vla-EndUndoMark doc))) (setvar "CMDECHO" oldc) (princ)) Quote
Tommy78 Posted October 15, 2009 Posted October 15, 2009 Are you rotating the block using a dynamic rotate action or manually? If with a dynamic action it is possible you haven't linked the other actions to your rotate action which causes your action selectors to not move along with the rotated block. Quote
GE13579 Posted October 15, 2009 Posted October 15, 2009 That's why I was hoping the OP could post the block Tommy :wink: Quote
