09 CAD Mechanical - HOW TO RETAIN MIDPOINT SETTING
Hello: For some reason, when i right select the osnap and click to select the midpoint, it retains it's setting only until I need it again...then i see it's deselected again. I'm not sure why this setting is not retaining ....
thanks,
Proctor
Is Object Snap toggled on? It's the F3 key.
Hi Remark...thanks for your help. when i enter F3, it says osnap off...so I suppose that means it was on - correct?
Thanks,
Proctor
maybe there's some global setting that i need to set...? not sure....i'll research it.
Your using the Shift+right-click method? Did you try setting Midpoint via the Osnaps Settings instead?
I've tried it both ways...it just won't stay set. very strange.
When do you set the snaps? I have found that if I set the snaps while I am in a command they only last till the end of the command (or so). On the occasions that I have remembered this and set the snaps with no command running they seem to hold.
Glen
