TheCan Posted October 19, 2009 Posted October 19, 2009 Hi! I'm having a scale-problem when inserting a layout from one drawing(A) to another (B) using the command layout;t; For some reason the layout that's inserted in my drawing (B) get scaled by some factor. I've the same units (meter) in both drawings and the annotation scale are also the same. I tried to do it the other way around, inserting a layout from B to A and then there are no problem. Any ideas? Quote
Strix Posted October 19, 2009 Posted October 19, 2009 Does this shed any light on the situation for you? Quote
Glen Smith Posted October 19, 2009 Posted October 19, 2009 Can someone clarify why according to the FAQ - INSUNITS 13 and 14 are both microns? According to the help file in 2010, INSUNITS 14 should be Decimeters. Glen Quote
TheCan Posted October 20, 2009 Author Posted October 20, 2009 Strix: I have INSUNITS, INSUNITSDEFSOURCE and INSUNITSDEFTARGET set to 6 in both drawings but the layout still gets scaled... Quote
dbroada Posted October 20, 2009 Posted October 20, 2009 what is the scale factor? constant or random? Quote
TheCan Posted October 20, 2009 Author Posted October 20, 2009 dbroada: I think it's constant. The layout gets scaled with a factor of 1000, which indicates a typical meter to mm problem, but i can't find out what is the problem... Quote
dbroada Posted October 20, 2009 Posted October 20, 2009 have you gone in to the "problem" file and checked that the units are set to 6 in there. I have had problems with the INS* variables not behaving as expected in the past. Quote
TheCan Posted October 20, 2009 Author Posted October 20, 2009 yes I've set the INS* variables in both files Quote
dbroada Posted October 20, 2009 Posted October 20, 2009 and the UNITS? It sometimes seems to override the INS* variables. Quote
TheCan Posted October 20, 2009 Author Posted October 20, 2009 The units are meter i both drawings Quote
dbroada Posted October 20, 2009 Posted October 20, 2009 Sorry, but that's me out of ideas then. Quote
