what is selection set
Hi i am new for autocad
can anyone help what is selection set and explain it briefly
A selection set is the set of entity names that you have selected to do something ( copy move erase etc ) with.
So when you start the copy command, ACAD asks you to select the entities you wish to work with. HTH -David
neelima: What is it that needs further explaining? I thought David's explanation was pretty clear.
