Steward Posted October 20, 2009 Posted October 20, 2009 Hi All I have recently come back to 3D modelling after not using for nearly 10 years. I have picked up the new software quite quickly as i have been using the 2D package over that period and have used Sketchup although infrequently. My problems seem to occur when I try to print from my model. I would like to print in 3D Hidden but all i get whether to PDF or the work printers is what you see on the attached link. I would also like to print conceptual isometric views of the model but when I try they come out pretty bad quality no matter how high i set the DPI. Although they are only simple colours it would be nice to have more precise and defined lines. I have a feeling that this may need rendering and if that is the case just let me know and i can research that aspect of the package. Any help with this issue would be greatly appreciated. I am using AutoCAD 2010 Many thanks in advance 3D Hidden.pdf Conceptual.pdf Quote
Ringis Posted October 21, 2009 Posted October 21, 2009 Hallo! I´m using Architecture 2009 and in my Swedish verison we have an display configuration called "presentation" and when we make PDF´s or hardcopys they look really good. Sharp lines and colors are ok. Post a part of your file and I will make a PDF as a test for you. If that is what you looking for, I´m sure there is way to set the display config on your version as well. //Tobias Quote
Steward Posted October 21, 2009 Author Posted October 21, 2009 Hi I cannot get the filesize below the limit and i need to have posted 9 times before i can include a link for you and i am only on 6. Do you have an example you could post? Quote
Steward Posted October 21, 2009 Author Posted October 21, 2009 Lets hope this works. https://rcpt.yousendit.com/758321637/1828b2092c35dcf3f55599c99d0a927c How do you set the display configuration? The only thing I can find that is similar is the DPI settings when printing. Cheers Quote
Ringis Posted October 22, 2009 Posted October 22, 2009 Hallo again! I have downloaded your file, and converted it in TruwView but I get a Fatal Error opening it in 2009, can you export to DWG 2007 format and I will give it a try. I made a quick example for you with a box in conceptual and in presentation, I use PdfCreator. I think It looks ok, of course the lines are not precise, but when I make a hardcopy on our printer It looks very good. The example in conceptual is printed in modelspace, and the presentation is from a layout tab i call Presentation and is controlled by the display config. It uses the materials you choose on your objects. I hope you understand, and remember that I´m using Architecture. I have not made this display config, it comes from our Cad firm that deliver our programs. Yo can Email me your file at tobiasasa?hotmail.com /Tobias Box conceptual_400dpi.pdf Box presentation_300dpi.pdf Quote
