Hi, I had a problem in AutoCad 2009 LT in Xbind the Xref . I did the command Xbind then clicked the xref drawing then add but it doesn't work not sure I'm doing right. I can xbind an xref in Lower Autocad such as 2006 but in Autocad 2009LT not sure what's happening . I want to bind the drawing so it will become a block and explode to use it. This is a large files of a traffic lane and street .
bump, any answer ?????Please!!
LoL
I can see patience is your strongest suite.:roll:
It could be that the xref cannot be bound due to having nested xrefs.
Sorry Alan, I needed so much information and suggestions in this forum I know there's alot of Good Guys like you here. Should I go to the original drawing and just copy and paste the drawing. I just needed the street drawings and place all the traffic sign though. I was thinking I can do that way, If ever there is original drawing I know there is. Thanks for responding.
Yeah, just copy/paste everything you need.
