GMPAO Posted October 21, 2009 Posted October 21, 2009 Is it possible to enter a line as an angle without knowing the @ #,# and only knowing the line distance? Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 You want to enter just the coordinates like this? Command: _line Specify first point: 0,0 Specify next point or [undo]: 120,120 Yep...it's doable. No @ symbol required either. Quote
GMPAO Posted October 21, 2009 Author Posted October 21, 2009 Ok, just so I better understand, if I have a 13' long line and I want it at an angle I will type 0,0 then ENTER and type 13,13 ENTER? Quote
Tankman Posted October 21, 2009 Posted October 21, 2009 Ok, just so I better understand, if I have a 13' long line and I want it at an angle I will type 0,0 then ENTER and type 13,13 ENTER? OK, so I'm a bit confused. Don't know the angle? Pick a starting point, from the command line, @13 This will give you a line 13 units long, from your starting point, to 0° (or to the right). You can always rotate the line if needed later. Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 You want to draw a line and you DO or DO NOT know the angle? Which is it? Quote
GMPAO Posted October 21, 2009 Author Posted October 21, 2009 I know th length of the line that's at an angle is 13' but I don't know which coordinates will get me there. Quote
stevsmith Posted October 21, 2009 Posted October 21, 2009 Or you can select the 1st point of your line, aim in the direction you want to go (make sure ortho is off) type 13 hit enter. Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 Type the angle in then if you do not know the coordinates. Like this: @13' The input for the angle depends on the angle type that you have specified in Units. The above example uses Degs/Mins/Secs with a Precision of 0d00'00". Does that work for you? Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 Drawing precisely would require that you know either the exact angle or the exact coordinates. If you have neither then you aren't drawing as much as you are sketching. It all depends on how accurate you want to be. If accuracy doesn't matter skip CAD altogether and get out your pencil and paper. Quote
GE13579 Posted October 21, 2009 Posted October 21, 2009 If you don't know the angle or the coordinates- then unless you have something to snap to or reference from, you've got your work cut out! Quote
GE13579 Posted October 21, 2009 Posted October 21, 2009 You can always use TRIM, EXTEND or LENGTHEN if you have a point which references the angle? Quote
GMPAO Posted October 21, 2009 Author Posted October 21, 2009 Thanks ReMark. That seems to be working. Now how do I get the 45 angle to slant down and right? Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 AutoCAD turns angles counterclockwise. "0" degrees happens to be at the 3 o'clock position. 90 degrees is at 12 noon, 180 degrees is at the 9 o'clock position and 270 degrees is at the 6 o'clock position. Follow me so far? It sounds like you want your line to be at an angle of 315 degrees based on what I just told you right? Then as an example you would type: @25' Does that work for you? Quote
GE13579 Posted October 21, 2009 Posted October 21, 2009 Or -45°... Be careful as you can change the orientation of 0° though. Quote
GMPAO Posted October 21, 2009 Author Posted October 21, 2009 That's exactly the info I needed! Thanks so much for your time ReMark and everyone else also! Quote
rkent Posted October 21, 2009 Posted October 21, 2009 Turn Polar on and set the increment angle to 45 Quote
alanjt Posted October 21, 2009 Posted October 21, 2009 Command: l LINE Specify first point: Specify next point or [undo]: <45 Angle Override: 45 Quote
rkent Posted October 21, 2009 Posted October 21, 2009 Command: l LINE Specify first point: Specify next point or [undo]: <45 Angle Override: 45 For this example he would need to use Quote
alanjt Posted October 21, 2009 Posted October 21, 2009 For this example he would need to use It locks it in for the specified value and the (+ value 180). Quote
